: C4 Corvette Forums
smog pump
how do i remove the smog pump on my 86 vette
#2 |
Do you plan on removing it or replacing it?
Office:201-258-5600 Cell:201-403-3699 www.injectorsplus.com www.facebook.com/InjectorsPlus Custom fuel injectors for any application, marine, ATV, etc Tuning stock and aftermarket ECUs Fuel Pumps----Areomotive and Fuel Labs Lines Fittings ---- Red Horse, Fragola, XRP MARCELLA CUSTOM INTAKES ECU-----Fast, Holley, and Motorvation Intakes Manifolds for LSX, SBC, SBF, BBC Carb to FI conversion kits If it's fuel related and you don't see it, CALL, we can make it. |
#3 |
I want to take it off
#4 |
Unbolt the bracket, you'll need the eliminator bracket probably from Ecklers or Mid America.
Take out the tubes on top of the headers. I say cut them off and weld up the holes. Also, there's a black box that sits under the throttle body. There's a bunch of wires that go to it to activate solinoids. Get rid of all that. there's a bunch of hoses too that run in and around the t-stat housing and such. get rid of all that crap. 30 lbs of useless stuff. It's an easy job, you'll be AMAZED how much crap comes out and how much more room you'll have without it in there. There's a hard stainless line that goes down to the converter. That will be the hardest thing to deal with.
#5 |
thanks ill give it a try in the morning
#6 |
Do you have the eliminator bracket and pulley?
#7 |
You don't really need to spend the money on the eliminator bracket. You can gut the smog pump by breaking off the plastic fins inside of it. Reinstall smog pump, and it will work fine as a pulley, provided it spun fine before. I did, works with no probs.
Go to the hardware store and get some nice brass caps to cap off the exhaust manifold tube.
http://i926.photobucket.com/albums/a...g?t=1285558094 |
#8 |
Smokin 2500HP Pro Road Racer
Make sure you tape up the redundant wires safely.The pink / blacks are hot with the key on
#9 | |
Do what he said. I'm tellin' you guys I went through this in the 90's. Don't tear off all the smog crab because the enviro-police will be coming back, and then you'll be hunting all this imposable to find stuff. By pass all the emissions crap but make it appear as though it's still there.
#10 | |
After the first five minutes, it has Zero effect on emissions.
All times are GMT -8. The time now is 08:09 PM. Powered by vBulletin® Version 3.8.4 Copyright ©2000 - 2013, Jelsoft Enterprises Ltd. |
