: C3 Corvette Forums
: C3 Tech & Performance
engine transmission removal
How do i get the shifter out so i can pull the motor and transmission, 1974 coupe standard transmission.
#2 |
If by standard, you mean manual transmission, here's an example picture of a shifter and linkage.
![]() I don't mean to sound crass but honestly speaking, if you are having trouble just separating the shifter from the transmission, your success rate of removing the engine and transmission without damaging anything is not good... much less working on either and re-installing both properly. That being said, there's only one way to learn When I did mine... In a nutshell, I removed the three linkages to separate the shifter from the transmission. I marked each linkage to identify and note length, then I took pictures. I then disconnected the shifter from the linkages at the shifter side, labled "linkage g clip" above. I then disconnected the 3x linkages from their respective levers because I figured I'd bend them if they were there. Good luck and most importantly, have fun & welcome to SV! Last edited by Sleeper; 06-05-2010 at 06:13 PM. Reason: speeling |
All times are GMT -8. The time now is 12:16 AM. Powered by vBulletin® Version 3.8.4 Copyright ©2000 - 2013, Jelsoft Enterprises Ltd. |
