Does water actually cool better than antifreeze? - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C5 Corvette Forums : C5 Corvette General Discussion : Does water actually cool better than antifreeze?
1997 - 2004 Corvettes Sponsored by
NakidParts.com
Old 02-03-2010, 06:25 AM   #1
speedingbullet
Smokin 50HP Club
Default Does water actually cool better than antifreeze?
I am running 50/50 but some people say that it will run cooler with more water?
speedingbullet is offline
Old 02-03-2010, 06:32 AM   #2
hokies83
Yes that's true but with the 50/50 your not risking anything. Useing only water you got some risks.
I run 50/50 cause there not worth it to me .
Parts so Far Ported HSR intake with TB spacer Melrose headers Random tech bullet cats more to come!
Goal is 400+ chp and 400+ c ft lbs tq!
Parts to come Ls7 Lifters 1.6 rrs 195 cc raceing heads bullet cam with custom grind.
All build advice is welcome!
hokies83 is offline   Send a Private Message Reply With Quote
Old 02-03-2010, 06:34 AM   #3
jimmymack
jimmymack's Avatar
Water makes better SOUP!!!!!!!!!
2001 C5 cpe 6 spdAMERICAN RACING HEADERS ///a.F.E Stage 2 C.A.I ~ SLP LOUDMOUTH ~ NITTO 555 Extreme~PFADT Competition sway bars ~PFADT Adjustable sport shocks~MGW short throw shifter ~ECS TUNE Smokinvette Video>>http://www.youtube.com/watch?v=Ob5GxEf1cDg>>"C5 CHICK" Artist "THE CARS OF SMOKINVETTE"
jimmymack is offline   Send a Private Message Reply With Quote
Old 02-03-2010, 08:55 AM   #4
RIGE-RNR
Smokin 2500HP Pro Road Racer
RIGE-RNR's Avatar
run coolant its engineered for a reson
RIGE-RNR is offline   Send a Private Message Reply With Quote
Old 02-03-2010, 09:03 AM   #5
aprilfool
Smokin 300HP Club
aprilfool's Avatar
Antifreeze is specially formulated to not only help cool your engine and prevent freezing in cold climates, but to lubricate the water pump and prevent internal corrosion. Run it with antifreeze!
aprilfool is offline   Send a Private Message Reply With Quote
Old 02-03-2010, 09:31 AM   #6
CorvetteDon
CorvetteDon's Avatar
Plain water boils at a lower point than water/antifreeze.
The only place you shouldn't run antifreeze is in drag racing. You don't want to mess up the track in the event of failure!
CorvetteDon is offline   Send a Private Message Reply With Quote
Old 02-03-2010, 10:08 AM   #7
Slicktop
Slicktop's Avatar
If you run plain water you will ruin the aluminum parts of your engine and cooling system that are exposed to it thru corrosion.
Old 02-03-2010, 10:19 AM   #8
fishslayer143@yahoo.com
stick to 50/50 mix, if you need to start modifying your coolant mix to cool your motor, you have bigger problems . improve the system not the coolant ratio.
Old 02-03-2010, 12:10 PM   #9
oldcars
oldcars's Avatar
Default Water cools better
Actually, water cools better than antifreeze or a water-antifreeze mix. The heat transfer capability of water is over twice as great as that of antifreeze. see http://www.redlineoil.com/content/fi...ech%20Info.pdf
You do not want to run straight water in your Corvette. If you do, you will need to put in some additives for corrosion protection and lubrication of the water pump.
The higher boiling temperture alluded to in an earlier post comes from the system running under pressure. The water-antifreeze mix has about the same boiling point as water when at about 15 pounds of pressure.
The main benefits of a water-antifreeze mix is corrosion protection, water pump lubrication, and a lower freezing point. Better cooling and higher boiling point are not two of the benefits.
oldcars is offline   Send a Private Message Reply With Quote
Old 02-03-2010, 12:25 PM   #10
I agree with most of that the exception being that antifreeze does not raise boiling point . It does ,to 265 degrees . read the back of any Prestone container. Water will boil before that even under pressure. ,http://www.newton.dep.anl.gov/askasc.../chem03987.htm ,read for yourself
All times are GMT -8. The time now is 07:23 PM. Powered by vBulletin® Version 3.8.4
