Removing ECU/TPI and installing carb. 1986 C4 - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Corvette General Discussion : Removing ECU/TPI and installing carb. 1986 C4
1984 - 1996 Corvettes
Old 01-27-2010, 07:22 PM   #1
fordean
Smokin 300HP Club
Default Removing ECU/TPI and installing carb. 1986 C4
1986 C4,
Anyone have any suggestions. Removing ECU and Tpi and installing carb. Would like to Get a holley stealth ram in future. But now carb is in. Distributor and associated items that need to be addressed I like to hear. What rewiring to trans or oil senders etc. Do They have a ECU wiring diagram. just for viewing.
Plus I have a 4+3 Dougy. I am going to install a tremec soon. But may put Dougy back in til monies arrive. Problem Dougy 4+3 dumps second gear on slowdown. Any info. Can I still retain stock distributor or should I upgrade it. Or toss it for A vac advance
fordean is offline
Old 01-27-2010, 07:31 PM   #2
hokies83
Hey man throw us some dyno numbers you get with the stock engine with a carb ive always wondered thx a bunch and good luck !
hokies83 is offline   Send a Private Message Reply With Quote
Old 01-27-2010, 07:37 PM   #3
slrvette
slrvette's Avatar
Why would you need to remove the ecm?
Yeah its a 84 thats HSR EQUIPPED BABY! AND RED APPROVED
388 Roller, custom grind cam, HSR, True dual exhaust,Borla and much more
In Loving memory of my first son Brandon Harley. 5/18/09- If only I could have seen him open his eyes.
May he rest in peace, in our hearts and never forgotten
slrvette is offline   Send a Private Message Reply With Quote
Old 01-27-2010, 08:39 PM   #4
LT1-84
Smokin 500HP Club
LT1-84's Avatar
You need a vac. adv. distributor, just unplug F.I. harness & keep it with the TPI, they are still sellable. You are very limited on hood space, you have to run a low intake or cut your hood. My car has a carb, custom hood, if you have any ?s let me know Ill do what I can.
LT1-84 is offline   Send a Private Message Reply With Quote
Old 01-28-2010, 12:09 AM   #5
vetteoz
Smokin 2500HP Pro Road Racer
Originally Posted by fordean View Post
Distributor and associated items that need to be addressed I like to hear. Can I still retain stock distributor What rewiring to trans or oil senders etc.
Low rise intake (Performer RPM ) and drop base air cleaner clears .Can run any non computer controlled dist
Need bypass fuel regulator to drop EFI pressure down for carb; kep stock pump and lines
Need means of controlling fans ; temp switch in head
Need a manual switch for the 4+3 O/d unit
If you plan on running HSR later can just tuck the unused injector wiring down on top of trans with zip ties
Problem Dougy 4+3 dumps second gear on slowdown. Any info. or should I upgrade it. Or toss it for A vac advance
Most likely the selectors and synchros are worn allowing it to pop out of gear when the load come off
Old 01-28-2010, 12:10 AM   #6
vetteoz
http://www.chevythunder.com/198689_f...dy_1227165.htm
Old 01-28-2010, 02:42 PM   #7
fordean
Smokin 300HP Club
Not stock any more, New Cam, Hyperte Dome Pistons. etc.
I like the response. Much appreciated. ANy brands.! I am much into a good spark. Plus I got hooker type Headers .They block all spark plugs need to dump it. Any solutioN>
Intend on cutting Hood and adding Scoop. Looks like I need a inch or two.
I did install Performer RPM. Dont know if it low rise type. I verify. Thanks. Motor was built by other.
fordean is offline   Send a Private Message Reply With Quote
Old 01-28-2010, 02:47 PM   #8
fordean
Smokin 300HP Club
Thanks. Good Response.
Old 01-29-2010, 08:13 AM   #9
generallee23
generallee23's Avatar
I like the hooker headers!
generallee23 is offline   Send a Private Message Reply With Quote
Old 01-29-2010, 11:28 AM   #10
fordean
Smokin 300HP Club
how they line up with Spark plugs??
All times are GMT -8. The time now is 01:47 PM. Powered by vBulletin® Version 3.8.4
