Horn Doesn't Work - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C5 Corvette Forums : C5 Corvette General Discussion : Horn Doesn't Work
1997 - 2004 Corvettes Sponsored by
NakidParts.com
Old 01-08-2010, 04:07 PM   #1
3vettes
Angry Horn Doesn't Work
I just joined Smokinvette, so bear with me. I own a 1998 Vert, my horn doesn't work. I checked under the hood and the fuse was OK, however the relay was missing. I bought a relay and after I put it in place about 2 minutes later the horn went off and would not stop until I pulled it out. I was thinking that the horn switch is stuck, does this make sense? Also is it a hard job to fix the switch?
3vettes is offline
Old 01-08-2010, 05:42 PM   #2
Drivethevette98
Drivethevette98's Avatar
Had the same problem. Check the bolts on the backside of the steering wheel air bag, mine were loose and caused the ring to make contact and sound the horn in the middle of the night (pissed off the neighbors).
Drivethevette98 is offline   Send a Private Message Reply With Quote
Old 01-09-2010, 01:58 PM   #3
sircharles
lol! I've heard of that happening! lol
sircharles is offline   Send a Private Message Reply With Quote
Old 01-10-2010, 08:39 AM   #4
3vettes
I tried to tighten the torx but I don't have the right size. I put the relay back in place and the horn went off, however when I turned the steering wheel the horn stopped. It would only stop going off in one position. Now I'm totally lost. Thanks for the info.
3vettes is offline   Send a Private Message Reply With Quote
Old 01-11-2010, 06:12 AM   #5
git-r-done
git-r-done's Avatar
Can you get the right size tool? Then tighten it and then see what happens.
git-r-done is offline   Send a Private Message Reply With Quote
Old 01-12-2010, 07:31 AM   #6
Raydawg357
Raydawg357's Avatar
If your horn is constantly blowing, it's grounding out somewhere. Most part stores will loan you the torx bit you need.
Raydawg357 is offline   Send a Private Message Reply With Quote
Old 01-12-2010, 08:50 AM   #7
n8dogg
could very well be the horn switch stuck, you can try hitting the switch, just be careful. If it interupts the sould you know where your problem is. Hardest part is removing the air bag. Might want to have a dealer do it, you need a special tool (large tweezers, with an angle at the ends) to remove the bag.
n8dogg is offline   Send a Private Message Reply With Quote
Old 01-12-2010, 01:57 PM   #8
3vettes
Thanks for all the help, I'll try again this weekend.
Old 01-13-2010, 06:51 AM   #9
smokinC5
Smokin 300HP Club
smokinC5's Avatar
Good luck bro!
You only go around once, so you might as well go around with a Vette!
T.M.
smokinC5 is offline   Send a Private Message Reply With Quote
Old 01-13-2010, 07:18 AM   #10
ovrpar6
ovrpar6 is offline   Send a Private Message Reply With Quote
All times are GMT -8. The time now is 08:36 PM. Powered by vBulletin® Version 3.8.4
