1984 Corvette "LS1" Engine Swap/Build - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Corvette General Discussion : 1984 Corvette "LS1" Engine Swap/Build
1984 - 1996 Corvettes
Old 12-27-2009, 06:31 PM   #1
eilax53
eilax53's Avatar
Default 1984 Corvette "LS1" Engine Swap/Build
Well I finally realized I never posted this here... I have on other forums and decided to post it here as well... Enjoy and the posts are just copied so the wording might not make sense. These are posts spread apart a time frame of about a month... Enjoy
Well after some research I have decided to do an "LS1" Engine Swap/Build. This was the thread that convinced me to do this swap...
Click HERE
and I started to wonder if anyone has done this swap in a C4. It turns out that corvette fever has done this swap in a C4 and its called Project C4orce. Once I saw that I knew that, that was the engine swap I wanted to do. The reason I'm not doing an actual LSx swap is because it is too much money for a high school kid.
So today I managed to get down to the junkyard and pick up an LM7 327 (5.3L) engine from a 2000 Chevy Silverado 1500. It has 52k miles on it and cost me $600. It seems to be in good condition and everything but I have 30 days to return it so I am going to be doing compression test and a leak down test first. Once its good I will be swapping the truck intake for an LS1 intake, fuel rails, and injectors that I bought used for $130 (still waiting for it to come in the mail). All I need to get the motor running is a LS1 harness and ECM then it will be good to go for the swap.
eilax53 is offline
Old 12-27-2009, 06:31 PM   #2
eilax53
eilax53's Avatar
Here are some pics of the motor the way it is now (how it came from the junkyard)
It came with everything besides an alternator and belt.
My Ls1 Intake
eilax53 is offline   Send a Private Message Reply With Quote
Old 12-27-2009, 06:32 PM   #3
eilax53
eilax53's Avatar
My Ls1 Intake
Old 12-27-2009, 06:33 PM   #4
eilax53
eilax53's Avatar
Well got it set up in the garage on a stand and started to rip it apart
Intake off
Cleaning it up and took off all the accessories
Old 12-27-2009, 06:33 PM   #5
eilax53
eilax53's Avatar
Heres a quick test fit
Well finally got some free time to get a little work done on the engine. I spun it upside down and took off the oil pan to check out the bottom end and look at the cylinder walls. It looks great. You can still see a slight bit of cross-hatch pattern on the walls.
And heres the difference between the truck oil pan and the Firebird pan.
Now im back on hold untill the new windage tray arrives. Also in the market for an LS1 harness and ECM. Might start disassembling the car to get ready to pull the crossfire
Old 12-27-2009, 06:34 PM   #6
eilax53
eilax53's Avatar
Got some more work done...
Windage tray and pick-up tube installed
Oil pan installed
[/URL]
Coolant Lines and knock sensors installed
Intake, Valve Covers, and coil packs installed
Engine Harness installed (for now)
I gotta figure out some things about the harness since there seems to be extra wires that I dont think I need. This week I am off from school so I should get a lot of progress done on the engine
Old 12-27-2009, 06:35 PM   #7
hokies83
Nice man! but i would of saved up and got the ls1 you can find them kinda cheap now =p
But anyways looks like a fun project. how much did that tent type garage cost you i been wanting to get 1
hokies83 is offline   Send a Private Message Reply With Quote
Old 12-27-2009, 06:35 PM   #8
eilax53
eilax53's Avatar
Heres a look at the blizzard we got yesterday and yes thats the curb poking thro on the bottom :laughing:
Had to shovel a pathway to my car :laughing:
Heres some before shots
And the progress I got done today
I removed the air pump, alternator, power steering container, and the power steering pump (besides the one hose going to the rack, got to dark)
Old 12-27-2009, 06:36 PM   #9
eilax53
eilax53's Avatar
Removed the SMOG pump, A/C, distributor, radiator and shroud, crankshaft pulley, and hood.
Old 12-27-2009, 06:37 PM   #10
eilax53
eilax53's Avatar
Well... I have some more pics
This is what it looks like today... Will keep you guys posted as my progress continues
Tags
ls1
All times are GMT -8. The time now is 04:22 PM. Powered by vBulletin® Version 3.8.4
