What is the stock ride height of '05 - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C6 Corvette Forums : C6 Corvette General Discussion : What is the stock ride height of '05
2005 + Corvettes Sponsored by
B&M Racing
Old 12-12-2009, 09:57 AM   #1
Vette Dude
Vette Dude's Avatar
Question What is the stock ride height of '05
I lowered my Vette some time ago and was going to raise it back up a little. What is the factory height of a 2005 C6? What do you measure off of? The top of the lowering bolts or distance from leave spring to control arm??
Thanks
Vette Dude is offline
Old 12-12-2009, 04:56 PM   #2
talon90
talon90's Avatar
The Z trim height is the front ride height. The D trim height is the rear of the vehicle. The appearance of the height that you see when you look at the car is actually a tolerance stack up of the suspension components, weight of the vehicle and the variations in the adjustment from the factory. As you see below the table shows the specified nominal height and the allowable variation. The car should be at 1.81 inches but can be as low as 1.52 and as high as 2.06 and still be in specification. The trim height is measured per the following illustration (front drawing attached, rear is similar.)
Trim Height Specifications
RPO Service Preferred Tolerance
Metric English
Z Trim Height
FE1(Base) 46 mm (1.81 in) 39.6-52.4 mm 1.52-2.06 in
FE2 (F55) 46 mm (1.81 in) 39.6-52.4 mm 1.52-2.06 in
FE3 (Z51) 45 mm (1.77 in) 38.6-51.4 mm 1.52-2.02 in
D Trim Height
FE1 122 mm (4.80 in) 115.6-128.4 mm 4.55-5.05 in
FE2 122 mm (4.80 in) 115.6-128.4 mm 4.55-5.05 in
FE3 121 mm (4.76 in) 114.6-127.4 mm 4.51-5.01 in
Based on where the trim height is measured and when you consider the allowable tolerance in each of the components that are north of that measurement point, a lot of variation (perceived height) can be realized. There is no way to measure the fender or the arms to obtain a "stock" height.
Paul
NCM Lifetime Member
NCM Master Ambassador
2005 Precision Red Coupe - Born on 10/04/2004 Adopted 05/26/06
Past Corvettes
1997 TR Coupe. MN6 19I. Born on 04/15/1997
1984 Coupe
And yeah, we wave.
More photos on my site. www.theredlion.us/Redlion2.htm
http://smg.photobucket.com/albums/v610/talon_90th/C6/
and here:
http://photobucket.com/albums/v610/talon_90th/Corvette/
talon90 is offline   Send a Private Message Reply With Quote
Old 12-13-2009, 06:44 AM   #3
Yogi
Yogi's Avatar
Metric English
Z Trim Height
D Trim Height
Paul
That is one heck of a illustration
Yogi is offline   Send a Private Message Reply With Quote
All times are GMT -8. The time now is 10:40 PM. Powered by vBulletin® Version 3.8.4
