Vents on Bottom of Doors - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C5 Corvette Forums : C5 Corvette General Discussion : Vents on Bottom of Doors
1997 - 2004 Corvettes Sponsored by
NakidParts.com
Old 11-25-2009, 02:28 PM   #1
kelleyi
kelleyi's Avatar
Default Vents on Bottom of Doors
I'm thinking about purhasing Stainless Steel "dress-up plates" that attach to the bottom of the doors using 3M Tape. The plates will cover the vents on the bottom of the doors. So, what are these vents for and if cover them will there be a problem. Thanks all!
Ian R. Kelley
2ID "Second to None"
US FORCES KOREA
kelleyi is offline
Old 11-25-2009, 02:33 PM   #2
RIGE-RNR
Smokin 2500HP Pro Road Racer
RIGE-RNR's Avatar
they are there to circulateair in door are plates perforated you dont want to trap water in door
RIGE-RNR is offline   Send a Private Message Reply With Quote
Old 11-25-2009, 02:34 PM   #3
RIGE-RNR
RIGE-RNR's Avatar
by the way how did you make out with ecklers
Old 11-26-2009, 07:26 AM   #4
cloudbuster
cloudbuster's Avatar
I would like to also know how the Eklers ordeal panned out. As for the door things I have not even seen them before.
cloudbuster is offline   Send a Private Message Reply With Quote
Old 11-27-2009, 12:41 PM   #5
drlector
drlector's Avatar
drlector is offline   Send a Private Message Reply With Quote
Old 11-28-2009, 04:34 AM   #6
kelleyi
kelleyi's Avatar
Default Vents on Bottom of Doors.
I guess I'm a bit confused! If the vents are for air ciruclation and water drainage, why is there a rubber plug in the holes/vents? Thanks!
Ian R. Kelley
US FORCES KOREA
kelleyi is offline   Send a Private Message Reply With Quote
Old 11-28-2009, 07:10 AM   #7
mtndv8
Smokin 3000HP Drag Racer
mtndv8's Avatar
Default Hey Ian, Happy Holiday!
Have you considered a "dress up" of a different kind...?
Here's a few pics of my puddle light mod.
The wire is routed thru the outer rubber door "vent"...
I get comments on this mod the most...
I'll check my service manual a little later and see what it says about those rubber stoppers.
BTW; I like the new avatar pic!!
mtndv8 is offline   Send a Private Message Reply With Quote
Old 11-28-2009, 12:35 PM   #8
kelleyi
kelleyi's Avatar
Default Puddle LED's
I like it...! What wire(s) did you "tap-into" to get power to the LED's?
Ian R. Kelley
US FORCES
KOREA
Old 11-28-2009, 01:37 PM   #9
mtndv8
mtndv8's Avatar
Ian R. Kelley
US FORCES
KOREA
I thought you might like this idea...
...that was before I noticed you have lambo doors.
I understand the Stainless Steel dress up question, now. Just figured, with your interst in cove LED's...
I'll pm you about the puddle lights if you'd like.
So far I can't find any reference to the rubber stoppers in the door in my Service Manual, yet.
I wouldn't think it would be too big a deal to cover them. JMO.
Old 11-28-2009, 01:51 PM   #10
kelleyi
kelleyi's Avatar
Thanks for the quick response...! "Stainless Addiction" who makes the "cover plates" for the bottom of the doors has told me that will MOD the plates by cutting out opening where the rubber plugs are located. So, that takes care of the Stainless Steel Plate-Plug problem. But, I still want to add your "Puddle Light LED MOD"...I really do like the Blue Light effect which matches my Interior Blue LED's. So, anything you can tell or show me via pics of how you did your MOD is greatly appreciated.(e.g. wire size used, solder/wire-taps, where you get power from, etc,etc...I love details! Thanks again for the quick response and I am anxiously awaiting your reply...I need something to do over the coming Holidays!
Ian R. Kelley
US FORCES
KOREA
All times are GMT -8. The time now is 12:32 PM. Powered by vBulletin® Version 3.8.4
