C4 Clutch adjustment - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Corvette General Discussion : C4 Clutch adjustment
1984 - 1996 Corvettes
Old 10-30-2009, 09:04 AM   #1
GaryC
Default C4 Clutch adjustment
I bought a 1985 with manual trans that seems totally original, very well kept with 120,000 miles. I have to pump the clutch pedal to get in/out of gear. My mechanic replaced the master and slave cylinders and hose and that didn't help. Next was the disc, pressure plate and bearing but still no difference. The system has been bled with a vacuum while the slave was turned 45 degrees and STILL nothing. My car has been in the shop for 3 months and he's out of ideas. Any suggestions?
GaryC is offline
Old 10-30-2009, 09:15 AM   #2
95vette
95vette's Avatar
There was a lot of discussion on another forum about this last year. Seems that all of the new slave cylinders were assembled incorrectly and never worked right. Not sure if that is what you are experiencing, but having to pump up pressure does sound like it is either a bad slave or master cylinder.
95vette is offline   Send a Private Message Reply With Quote
Old 10-30-2009, 04:11 PM   #3
vetteoz
Smokin 2500HP Pro Road Racer
If everything is new you obviously have something bleeding down.
When I did same work to mine it was like new.
Old 10-30-2009, 05:12 PM   #4
ex-x-fire
Smokin 400HP Club
How are they bleeding the system? Using the pedal or a brake flushing machine? Try holding the pedal down flat, & gravity bleeding it. You might have to unbolt the clutch master, use a brake flushing mach. hold the master cyl. at a slight angle, the line (that goes down to the slave) needs to be higher, so the whole master fills up.
I hope that helps you. I was working on a mid 90s ranger that had a bleeding problem, the master was at a 45 degree angle when bolted to the fire wall. The effect is like turning a cup upside down & putting it into water, there will be a hugh air pocket.
ex-x-fire is offline   Send a Private Message Reply With Quote
Old 10-30-2009, 08:27 PM   #5
Brion57
Smokin 50HP Club
Brion57's Avatar
Just cause the master cyl is new doesn't mean it's good. I put a new master cyl on my 87 and it was no good. Drives you nuts when new parts are no good and you think they are. I would try another master. Take the new one apart and see if the rubber cup at the end plunger is cut. I bet it is. Later B.A.
Brion57 is offline   Send a Private Message Reply With Quote
Old 10-31-2009, 07:28 AM   #6
TouringMike
TouringMike's Avatar
Take it to a different shop.
Seriously.
I replaced my master cylinder a few years ago.
To bleed the system completely of all air, here is what I did after suffering thru the same symptoms you have.
Jacked up the front end, went under the car and removed the slave cylinder from bell holusing.
Removed cap from master cylinder and put a towel around the cup. Back under the car, I took a long, large philips screwdriver and pushed the slave piston all the way in. This caused the master to purge much fluid out of the cup. Released the slave, filled the cup, and repeated pushing the slave piston in. Did this 3 times.
Next, Filled the cup and put the cap back on master, re-assembled slave to bell housing and hooked clutch back up, had the wife jump in the car. Had her pump the clutch 20 or more times andf on the last pump/push, hold the pedal down. Bled of the slave, closed the bleeder, had wife release clutch pedal.
Clutch works as if it just came off factory floor.
15 minutes/ done.
TouringMike is offline   Send a Private Message Reply With Quote
Old 11-14-2009, 04:47 AM   #7
GaryC
Many thanks for all the help. A combination of everything worked well enough to get my car out. I still have to go a bit deep to disengage but I can live with it. THANKS GUYS
GaryC is offline   Send a Private Message Reply With Quote
Old 11-14-2009, 11:05 AM   #8
I agree. If you have to pump the pedal to get the clutch to release, then the clutch's master cylinder is bad. Or it still has a bunch of air in it.
Old 11-16-2009, 08:23 AM   #9
khan2305
khan2305's Avatar
sounds like it to me, I remember that discussion on the other forum you are talking about.
khan2305 is offline   Send a Private Message Reply With Quote
Old 11-16-2009, 06:09 PM   #10
86 vett vert
Smokin 500HP Club
86 vett vert's Avatar
another thing as far fetched as it may sound is try a little bead of weld on the end of the fork on clutch peddle it gives you just a little more adjustment on the clutch it worked for me when i rebuilt the trans,and put a new clutch pressure plate and throwout bearing in last year let me know how you make out the fork does ware out and was a easy fix once i figured out to give it a try ,it worked and have not had any problems since
86 vett vert is offline   Send a Private Message Reply With Quote
All times are GMT -8. The time now is 08:29 PM. Powered by vBulletin® Version 3.8.4
