Photos of splash guards installed on C6? - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C6 Corvette Forums : C6 Corvette General Discussion : Photos of splash guards installed on C6?
2005 + Corvettes Sponsored by
B&M Racing
Old 08-23-2009, 07:41 AM   #1
iBlue
Smokin 300HP Club
iBlue's Avatar
Question Photos of splash guards installed on C6?
What splash guards do you have installed on your C6? Would you mind posting a photo of front and rear showing what splash guards you have?
2008 C6 Z51 Convertible Corvette
iBlue is offline
Old 08-23-2009, 08:35 AM   #2
CYBER6
CYBER6's Avatar
I have the GM, got them from Parts Taxi.
My Plastic Fantastic: http://i978.photobucket.com/albums/a...1/P1010745.jpg
2009 Cyber Gray, Ebony, 3LT, 6Speed, Dual Mode Exhaust (ALWAYS OPEN), Z51, Chrome Wheels, ZR1 Spoiler, Prostart Vette Components-Rear Brakes www.prostartracecars.com
_____________________
Going, Going>>>>>>>>>> But Not Gone
CYBER6 is offline   Send a Private Message Reply With Quote
Old 08-23-2009, 09:30 AM   #3
YellowFever
YellowFever's Avatar
Awesome!!! I just rec'd mine from Parts Taxi Friday via UPS.
Did you install them or have the dealership do it? Is it an easy install?
Any detailed help in the installation procedure would help me greatly.
I am not the shadetree mechanic I inspire to be!!!
YellowFever is offline   Send a Private Message Reply With Quote
Old 08-23-2009, 09:58 AM   #4
CYBER6
CYBER6's Avatar
I am very particular, so I spend more time making sure things are done right the first time. The tape makes it a little tricky to install, cause it's kind of a one shot deal. And my car is waxed to the point where (masking tape to hold the pieces in place) will not stick to it. The fronts use the factory holes, makes them go on pretty easy. You don't even have to remove the tires, just turn it one way. The rears require taking off the tire and drilling holes in the inner wheel well (be careful the drill bit will want to suck itself into the plastic wheelwell). I held the rears to where they fit the contour the best and drilled the holes through the piece. Using one of the bullets to hold the top and worked my way down installing the fasteners as you go. Then with the fasteners through the holes but not locked, you carefully remove the backing from the tape and press to the opening. If you just stick it to the panel gently you can adjust it slightly. Also do one side of the rear at a time, you can then measure from the bumper-quarter panel meeting line and position the other in the same place. This way they will both be even from behind..
Good Luck- feel free to ask me anything you would like.
Old 08-23-2009, 11:06 AM   #5
phileaglesfan
Smokin 400HP Club
phileaglesfan's Avatar
Nice! I plan on buying installing them soon.
phileaglesfan is offline   Send a Private Message Reply With Quote
Old 08-23-2009, 12:19 PM   #6
jmarch313
Does anyone know whether, or not, splash guards can be installed on new 2010 GS's? I saw my first one yesterday and the plastic wheel well liners appear to "roll" out to the body edges. Is it possible, or even needed to install GCA splash guards on the GS? Just wondering as I had intended to install them, but now am not sure that it is possible. Thanks!
jmarch313 is offline   Send a Private Message Reply With Quote
Old 08-23-2009, 12:20 PM   #7
wawuzit
wawuzit's Avatar
Smile Here's mine..
Mine are also GM parts.
If you wait..all that will happen is you will get older
wawuzit is offline   Send a Private Message Reply With Quote
Old 08-23-2009, 04:06 PM   #8
CYBER6
CYBER6's Avatar
I was wondering where my car went.
Old 08-23-2009, 05:36 PM   #9
YellowFever
Cyber6 thanks for the install information.
I will try this out next weekend and once done I will post some photo's
Old 08-24-2009, 12:44 AM   #10
bapd77
bapd77's Avatar
I've considered doing the splash guard mod myself!
bapd77 is offline   Send a Private Message Reply With Quote
All times are GMT -8. The time now is 02:04 PM. Powered by vBulletin® Version 3.8.4
