Proper way to disconnect battery? - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C6 Corvette Forums : C6 Corvette General Discussion : Proper way to disconnect battery?
2005 + Corvettes Sponsored by
B&M Racing
Old 08-05-2009, 08:09 AM   #1
OO___OO
Smokin 400HP Club
OO___OO's Avatar
Default Proper way to disconnect battery?
What's the smartest way to disconnect the battery on a C6.
both terminals? which one first...
Just the Red?
I've never been that good with electronics..
Any advice would be appreciated, I know these Vettes can be electrically temperaMENTAL!
I'm going to be under the hood checking O2 wires, spark plugs and wires, and cleaning ....
should I even worry about unplugging the car?
OO___OO is offline
Old 08-05-2009, 08:48 AM   #2
steveb601
I'm not a vehicle electronics expert either but I have never heard of a suggested method of removing the positive or negative terminal in some order to diconnect the battery, and I've worked on mine quite a bit without any adverse problems. But, maybe I'm missing something...
steveb601 is offline   Send a Private Message Reply With Quote
Old 08-05-2009, 11:27 AM   #3
Red Magic
Red Magic's Avatar
I've always just removed the ground first then the positive.
Current & Past Corvettes:
2007 C6 Rag Top - Current
2003 C5 Z06 - Traded in for current
1997 C5 Coupe - SOLD
1987 C4 Coupe - SOLD
Red Magic is offline   Send a Private Message Reply With Quote
Old 08-05-2009, 11:31 AM   #4
Default Which terminal do I disconnect first?
You ALWAYS disconnect the ground wire first, and re-connect the ground wire last. Notice how I used the term "ground" rather than "negative". Because in a positive ground system, in that case you disconnect the positive "ground" wire first.
Old 08-05-2009, 01:03 PM   #5
OO___OO
Smokin 400HP Club
OO___OO's Avatar
Thanks, guys.
I knew there was a particular way, in the event I do decide to unhook the batt.
OO___OO is offline   Send a Private Message Reply With Quote
Old 08-05-2009, 03:32 PM   #6
talon90
talon90's Avatar
As noted always the ground (In the Corvette this is the "-" or black) terminal first and if disconnecting both terminal also connect it last.
NCM Lifetime Member
NCM Master Ambassador
2005 Precision Red Coupe - Born on 10/04/2004 Adopted 05/26/06
Past Corvettes
1997 TR Coupe. MN6 19I. Born on 04/15/1997
1984 Coupe
And yeah, we wave.
More photos on my site. www.theredlion.us/Redlion2.htm
http://smg.photobucket.com/albums/v610/talon_90th/C6/
and here:
http://photobucket.com/albums/v610/talon_90th/Corvette/
talon90 is offline   Send a Private Message Reply With Quote
Old 08-06-2009, 11:38 AM   #7
Fatcat
Fatcat's Avatar
and don't stick your tongue on the terminals!
Corvettes of the past:
1986 C4 Corvette - Sold
1991 C4 Corvette - Sold
1997 C5 Corvette - Sold
2005 C6 Corvette - Sold
2008 C6 Corvette - Will have till the C7 Comes out!
Fatcat is offline   Send a Private Message Reply With Quote
Old 11-27-2009, 10:20 AM   #8
Shifter
Smokin 50HP Club
Shifter's Avatar
Ground is the first off and the last back on
Shifter is offline   Send a Private Message Reply With Quote
Old 11-27-2009, 11:22 AM   #9
Just the Red?
Always remove the ground wire first. And connect the ground wire last.
All times are GMT -8. The time now is 10:34 AM. Powered by vBulletin® Version 3.8.4
