  • Corvette Classifieds
  • SVC Store
       Share this thread: Bookmark to: Digg Bookmark to: Del.icio.us Bookmark to: Facebook Bookmark to: StumbleUpon Bookmark to: Myspace Post to: Twitter
Thread ToolsSpacerSearch ThreadSpacer Display Modes Spacer
Old 07-02-2009, 05:49 PM   #1
Corv2006
Smokin 50HP Club
Corv2006's Avatar
Question Where does GM conduct road test for Corvettes?
Anyone happen to know what track GM test Corvettes? Also was wondering what all do they test? Is every Corvette sent through some testing process? Or just random ones from the production line to keep with quality control?
Corv2006 is offline   Send a Private Message Reply With Quote
Old 07-02-2009, 06:25 PM   #2
talon90
talon90's Avatar
GM selects cars at random from the production process. These cars will be run on the squeak and rattle track and then taken on an up to 28 mile road test for evaluation on the plant grounds and around the neighboring area depending upon what they are looking for.
Each car as it rolls off the assembly line is put on a dyno and run through a series of tests. The car passes through a leak test where 6,000 gallons of water are poured over the car with pressurized spary and then out the back. Once the car leaves the plant, every Corvette is run on a squeak and rattle track that is 1/4 mile long out behind the plant. The car is then taken through a C.A.R.E. (customer acceptance requirement evaluation as I recall) where a team of inspectors goes over the car as a customer would taking new car delivery.
NCM Lifetime Member
NCM Master Ambassador
2005 Precision Red Coupe - Born on 10/04/2004 Adopted 05/26/06
Past Corvettes
1997 TR Coupe. MN6 19I. Born on 04/15/1997
1984 Coupe
And yeah, we wave.
More photos on my site. www.theredlion.us/Redlion2.htm
http://smg.photobucket.com/albums/v610/talon_90th/C6/
and here:
http://photobucket.com/albums/v610/talon_90th/Corvette/
talon90 is offline   Send a Private Message Reply With Quote
Old 07-02-2009, 08:15 PM   #3
Uncle Tom
Smokin 50HP Club
Uncle Tom's Avatar
Am I understanding you correctly that each car, not selected few will see a dyno at the factory? With that being the case is it possible to find out what the actual RWHP is prior to buying. I've heard cases where some Corvettes exactly the same get higher HP figures on base runs.
Uncle Tom is offline   Send a Private Message Reply With Quote
Old 07-03-2009, 03:17 AM   #4
talon90
talon90's Avatar
The dyno does not measure horsepower. They simply use the dyno setup to allow the car to be "driven" while stationary. They drive on to rollers, plug in the OBDII connection and take the car through a series of tests while monitoring system output for various sensors and systems. This is more of a rolling diagnostic as opposed to a conventional chasis dyno.
NCM Lifetime Member
Past Corvettes
1984 Coupe
And yeah, we wave.
and here:
Old 07-03-2009, 11:36 AM   #5
Johnny Checkers
Johnny Checkers's Avatar
Talon does GM open up these sort of test to be observed by general public? Might be fun to watch GM test these cars on track
Johnny Checkers is offline   Send a Private Message Reply With Quote
Old 07-03-2009, 02:54 PM   #6
talon90
talon90's Avatar
Unfortunately, no. It is behind the plant in an area that is not very accessible. They have safety concerns. However if you are driving on the grounds you might see part of the road test portion going on.
NCM Lifetime Member
Past Corvettes
1984 Coupe
And yeah, we wave.
and here:
Old 07-03-2009, 05:24 PM   #7
docholiday
Smokin 500HP Club
docholiday's Avatar
Isn't there a track or road course in Arizona that I recall hearing about GM using for road testing these cars? Or am I confusion something different?
docholiday is offline   Send a Private Message Reply With Quote
Old 07-03-2009, 05:45 PM   #8
talon90
talon90's Avatar
There are a number of tracks that GM uses including many of the road courses around the country and in Europe. Yes there is a test track in Arizona that they use for warm weather testing and endurance testing. They do a great deal of testing in Michigan at the GM proving grounds as well. I was of the impression that the OP was inquiring about testing of the vehicles at the assembly plant so that was how I tailored my answer.
NCM Lifetime Member
Past Corvettes
1984 Coupe
And yeah, we wave.
and here:
Old 07-03-2009, 05:50 PM   #9
docholiday
Smokin 500HP Club
docholiday's Avatar
Nothing wrong with your answer at all, I was just thinking to myself that I thought I remembered hearing something about a track or testing ground in Arizona some place.
« Previous Thread | Next Thread »
vB code is On
All times are GMT -8. The time now is 02:57 AM. Powered by vBulletin® Version 3.6.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright 2006-2007 © SmokinVette.Com
