Changing clutch fluid - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C5 Corvette Forums : C5 Corvette General Discussion : Changing clutch fluid
1997 - 2004 Corvettes Sponsored by
NakidParts.com
Old 11-21-2008, 07:24 AM   #1
airwolf99
Smokin 300HP Club
airwolf99's Avatar
Default Changing clutch fluid
Should I get the DOT 5? I am assuming that seeing it is higher then 4 it should be better?
airwolf99 is offline
Old 11-21-2008, 08:53 AM   #2
BLU COLLAR Z
BLU COLLAR Z's Avatar
The problem with Dot-5 silicone fluid is that it absorbs air causing air bubbles in the fluid, giving a mushy pedal. Use Dot-4; it is better than Dot-3 (higher boiling point with Dot-4), easy to obtain, & inexpensive.
BLU COLLAR Z is offline   Send a Private Message Reply With Quote
Old 11-29-2008, 09:16 AM   #3
Ron222
Ron222's Avatar
Should never mix Dot 3 or Dot 4 with dot 5. It's a no no.
Ron222 is offline   Send a Private Message Reply With Quote
Old 11-30-2008, 07:47 AM   #4
nuclearpowered
nuclearpowered's Avatar
You know, I just assumed that they were the same stuff just progressively better.
nuclearpowered is offline   Send a Private Message Reply With Quote
All times are GMT -8. The time now is 02:31 AM. Powered by vBulletin® Version 3.8.4
