My '07 C6(manual 6 speed) just will not shift in cold weather. Now, I'm talking about Southern Arizona cold weather, we aren't talk -20 degrees or even 0 degrees.
Under 60 degrees it hard shift, lower than 50 degrees, and it just won't shift at all. I'm having to place the car in the gear I need to leave the parking spot in (first or reverse) just to get it moving, after a while it loosen back up.
I've been told "well that's just the nature of the beast" to which I call BS!!
I'm using the Dot4 GM clutch fluid.
Is there anything I can do? Different fluid?
Thanks for any suggestions.
Tim
Tim
