What's the smartest way to disconnect the battery on a C6.
both terminals? which one first...
Just the Red?
I've never been that good with electronics..
Any advice would be appreciated, I know these Vettes can be electrically temperaMENTAL!
I'm going to be under the hood checking O2 wires, spark plugs and wires, and cleaning ....
should I even worry about unplugging the car?
I'm not a vehicle electronics expert either but I have never heard of a suggested method of removing the positive or negative terminal in some order to diconnect the battery, and I've worked on mine quite a bit without any adverse problems. But, maybe I'm missing something...
You ALWAYS disconnect the ground wire first, and re-connect the ground wire last. Notice how I used the term "ground" rather than "negative". Because in a positive ground system, in that case you disconnect the positive "ground" wire first.
Always remove the ground wire first. And connect the ground wire last.
Related Threads
Chevy Corvette Forum
669.9K posts
43.8K members
Since 2006
A forum community dedicated to Chevy Corvette owners and enthusiasts. Come join the discussion about performance, modifications, racing, restoration, classifieds, troubleshooting, maintenance, and more!
