http://www.exoticperformanceplus.com/performance_parts/index.html?item=1715
Check it out at the above link, with many options to choose from. Bob
* Callies Compstar 4.00 Stroke crankshaft
* Callies Compstar 6.125 H Beam connecting rods with ARP 2000 rod bolts
* Diamond forged pistons
* Comp/EPP blower camshaft 232/240 .595/.608 on 115 LSA or customer spec Comp camshaft
* Camshaft degreed in
* Total Seal file to fit piston rings
* Clevite main and rod bearings
* Cylinders are CNC Bored and Honed To Size with a Torque Plate
* Main Journals are Align Honed
* Crankcase is Stroker Clearanced
* Balanced rotating assembly
* Choice of compression ratio
* Sold outright, no cores required
* Built entirely from brand new parts
* Includes front cover
* Includes valley cover
* Includes Comp double row LS2 timing chain set
* Includes Comp Pro-Magnum hydraulic roller lifters
* Includes lifter guides
* 28 or 54 tooth reluctor wheel
* Oil pump not included
* Oil Pan not included
