I just received word that my chassis build will begin in July 2012 so I am getting excited and anxious as well. I continue to slowly take the 1964 Roadster apart so that I can lift the body off the old frame and get it soda blasted before the new frame from Street Shop arrives.
In the meantime, here are the specifications for the C5/C6 chassis I am having built by Street Shop (I plan to post pictures of the chassis build as soon as I get some photographs from the shop):
Street Shop C6 Based Chassis for 63-67 Corvette, Powder coated Semi-Gloss Black C6 C2 Chassis
Drive train
- M50 Series Dana Rear, 3.55:1 Ratio
- Billet Web for M50 Series Rear using C5/6 Suspension
- 1997-2004 Corvette Rear Suspension Cradle, Used, Modified for Street Shop C5/6 Chassis
- 80-93 Mustang Rack & Pinion Steering, Power Assisted
- Outer Tie Rod End, Moog
- Custom 1" Front Sway Bar Kit for Street Shop C5/6 based Chassis
- Street Shop Custom 7/8" rear Sway bar kit for C5/6 Based Chassis
- Custom Rear Axle Shafts for Street Shop
- C5/6 based Chassis Using M50 Differential, 14.5 bar
- Complete Custom Brake Line Kit
- 1963-1982 Corvette with Street Shop Chassis - Kit includes (6) Prebent SS Lines, (4) StopFlex SS Hoses with washers and Horse Shoe Clips, (1) Disc-Disc Prop. Valve and (2) Brake Tees
- LS Return-Style Fuel Filter
- C2/C3 3/8" Stainless Steel Fuel Line for Single line EFI LS Engine Applications
- 5/16" Fuel Injection Return Hose, Female 5/16" GM Push-Lock One end only, 60"
- 3/8" Fuel Injection Feed Line, #6 Female and Female GM Push-Lock
- 3/8" Fuel Injection Feed Hose, 45 deg. #6 Female and Female GM Push-lock Ends
- Fuel Line Kit for Single Feed LS EFI systems, Includes 3/8" SS Fuel line, Return
- Style Filter, Flexible Hoses from Fuel Rail to Chassis and Filter to Tank using GM-Style Push-lok fittings
- Hyerco Coil-Over Spring, 8" x 2.5" ID x 400lb Rate
- Coil-Over T bar Lower Mount Kit, 3/4" x 3.5" 2 18.90 37.80T
- QA1 VS Single Adjustable Coil-Over Shock, 3/4" Poly Ends
- QA1 Front Coil-Over Shock Kit
- QA1 Rear Coil-Over
- HyperCo Spring, 2.5"ID x 7", 500# rate
- Billet Lower Coil Over Mount; Use with Street Shop C5 and C6 based Chassis
- QA1 Rear Coil-Over Shock Kit
- C5/6 Right Front/Left Rear Spindle, New
- C5/6 Left Front/Right Rear Spindle, New
- C6 Front Upper Control Arm, New GM
- C6 Upper Front Control Arm, New GM
- C6 Lower Front Control Arm, RH, New GM
- C6 Upper Rear Control Arm, LH, New GM
- C6 Upper Rear Control Arm, RH, New GM
- C6 Lower Front Control Arm, LH, New GM
- C5 Rear Toe Link, New GM
- Outer Tie Rod End Kit, New GM
- C6 Lower Rear Control Arm, New GM
- C6 Lower Rear Control Arm, RH, New GM
- 97-07 Corvette Front Wheel Hub Assembly w/ Sensor, USA
- 97-07 Corvette Rear Hub Bearing Assembly w/ Sensor Ring, USA
- C5/6 Parking Brake Kit, New GM
- OEM Caliper Mount, Complete Set, C5
- Semi-Metallic Brake Pads, Complete set
- Rebuilt C6 Brake Calipers; complete set of four, Includes Core Charge, W/"CORVETTE", PC RED
- 97-04 Corvette Cross Drilled Rotor, Bendix, LH front
- 97-04 Corvette Cross Drilled Rotor, Bendix, RH front
- 97-04 Corvette Cross Drilled Rotor, Bendix, LH Rear
- 97-04 Corvette Cross Drilled Rotor, Bendix, RH Rear
Drive train
- LS3 Crate Engine, 436hp
- GM10349964 LS Engine Stand, LH
- GM10349965 LS Engine Stand, RH
- Vertical Mount Engine Cushion Kit
- LS Engine Accesories kit including Alternator, Power Steering, custom machined Waterpump and A/C
- GM LS3 Engine Mgmt. System with pre-programmed ECU, Harness, 02 sensors, MAF sensor and accl. pedal
- PowerMaster XS Torque Starter, LS
- GM12600987 LS3 Engine Cover, LH
- GM12600988 LS3 Engine Cover, RH
- GM11589406 LS Engine Cover Stud
- Bellhousing Shield
- Power Steering Pump Line Kit
- DeWitt's Custom Aluminum Radiator, HP
- LS series combo with fan for 63-72 Corvette
- 2 Wire 0-90 ohm Fuel Level Sending Unit, Adj., NOTE: 63-67 Corvette Gauges must be converted to Two wire to use this sending Unit.
- 63-67 Stainless Steel Fuel tank w/ Pump installed
- Universal Parking Brake Cable Kit w/Wilwood/Corvette Clevis
- Street Shop Pro Fit Kit for 63-82 Corvette, Kit Includes: Custom Modified C3 Corvette TKO 600, ProShift3 Shifter Mechanism, OE spec Shifter Handle, Bolt-in C3 Style Cross Member bracket, Polyurethane Isolator, Seamless DOM Driveshaft, TKO Slip Yoke, Solid U-Joints, Corvette to TKO Full Length Speedometer cable, Calibrated Speedo gear,
- HD Pilot Bearing, 5 speed name plate, Weatherseal Reverse Light Wiring, Grade 8 Hardware, Instructions/Warranty
- 11" Titanium/Aluminum Bellhousing for LS
- LS Clutch/Flywheel kit, New GM
- Grade 8 Pressure Plate Bolt, set of 6
- Billet Aluminum Bracket for mechanical clutch linkage for LS Engines in C2 Chassis
- Clutch Linkage Kit for C2 chassis
- 1963-67 corvette Level II Hydraulic brake Assist Sysytem w/ PS line set, 6 degree mount, Early/long GM MC Pushrod
- Wilwood Tandem Master Cylinder, 1.13" bore, polished
