I was wondering if anybody could tell me if I put a smog pump eliminator set-up on my 90 C4 if the check engine light stays on because when you remove the smog pump the tube from that goes to the passenger side to that breather unit with two computer connections on it, that is why I would think the light probably will come on and stay on, also should the E.G.R. be blocked off too?
Thanks any help I would really appreciate it!
i was wondering if anybody could tell me if i put a smog pump eliminator set-up on my 90 c4 if the check engine light stays on because when you remove the smog pump the tube from that goes to the passenger side to that breather unit with two computer connections on it, that is why i would think the light probably will come on and stay on, also should the e.g.r. Be blocked off too?
Thanks any help i would really appreciate it!
The smog pump draws negligible power. Removal to clean up under the hood is the only valid considferation. The egr is closed at wot. No gain in power by eliminating it. Only a loss in fuel mileage.
mine is a 90 too.
No CES if you remove the smog pump
been there, done that
PS: no gain in power with the smog pump eliminator.
Related Threads
Chevy Corvette Forum
669.9K posts
43.8K members
Since 2006
A forum community dedicated to Chevy Corvette owners and enthusiasts. Come join the discussion about performance, modifications, racing, restoration, classifieds, troubleshooting, maintenance, and more!
