Hi Guys & Gals...!
Thought it was time to get away from the Eagle F1 'Run-Flats' so I picked-out the Eagle F1 GS-D3's; I liked the specs and tread design. Unfortunately, it turns out that Goodyear has stopped production of these tires...my luck. So, I went with the Michelin Pilot Sport A/S Tires. These tires are a new addition to the Michelin lineup of performance tires and was wondering if anyone else has purchased these tires; if so, what do you think? Here are the tire specs!
Ultra High Performance All-Season
245/45-17 (Front)
95Y Load Index 95 = 1521lbs (690kg) per tire
Speed Rating “Y” = 186mph (300kph)
275/40-18 (Rear)
99Y Load Index 99 = 1709lbs (775kg) per tire
CUSTOMER SURVEY DATA (1-10)
Would Buy Again? Probably - 8.3
Hydroplaning Resistance 8.8
Wet Traction 8.8
Cornering Stability 8.7
Dry Traction 9.0
Steering Response 8.7
Light Snow Traction 7.6
Deep Snow Traction 6.8
Ice Traction 6.7
Ride Comfort 8.8
Noise Comfort 8.2
Treadwear 8.6
TIRE SPECS 17" 18"
UTQG Data A500 AA A A500 AA A
Max Load 1521 lbs. 1709 lbs.
Max Inflation Pressure 51 psi 51 psi
Tread Depth 10/32" 10/32"
Tire Weight 27 lbs. 30 lbs.
Rim Width Range 7.5-9" 9-11"
Meas. Rim Width 8" 9.5"
Section Width 9.6" 10.9"
Tread Width N/A N/A
Overall Diameter 25.7" 26.7"
Revs Per Mile 810 780
Country of Origin US US
Low Rolling Resistance N/A N/A
Price 17" $172.00 18"$223.00
245/45-17 (Front)
275/40-18 (Rear)
Wet Traction 8.8
Dry Traction 9.0
Ice Traction 6.7
Ride Comfort 8.8
Noise Comfort 8.2
Treadwear 8.6
TIRE SPECS 17" 18"
Tread Width N/A N/A
