SmokinVette.com Home
  • Corvette Forum
  • Login to Corvette Forums
  • SmokinVette.com
  • About SmokinVette.com
  • Corvette Forum
  • Corvette Gallery
  • Corvette Parts
  • Corvette Classifieds
  • SVC Store
  • Corvette Yellow Pages
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Corvette General Discussion : Throttle cable adjustment 92
1984 - 1996 Corvettes
Thread Tools Search this Thread Display Modes
Old 07-30-2010, 12:05 AM   #1
Snowweasel
Smokin 50HP Club
Snowweasel's Avatar
Smokin' Bucks $7.57
Unhappy Throttle cable adjustment 92
Hi Folks , How do you adjust a streached cable? I see a sticker that says see manual .But I don't have 1. thanks Pete
Snowweasel is offline
Send a Private Message Reply With Quote
Old 07-30-2010, 01:21 AM   #2
vetteoz
Smokin 2000HP Road Racer
Smokin' Bucks $64.10
Default
There is no cable adjustment unless you slot the holes in the mounting bracket.
Time for new cable
edit
The only throttle setup that is adjustable is if you have ASR ; there is a set procedure for doing it
__________________
"Being able to "think outside the box" presupposes you were able to think in it." --Bob Lutz
vetteoz is offline   Send a Private Message Reply With Quote
Old 07-30-2010, 04:59 AM   #3
todd_vette
Smokin 750HP Supercharged Club
todd_vette's Avatar
Smokin' Bucks $17.16
Default
You can buy an end peice that will allow you to trim the cable through it to adjust length. I did that once only to have the cable snap inside the housing (where it probably started streching) a few weeks later. So the streaching just means that it is about to snap on you and you better replace it before that leaves you stranded some-where.
todd_vette is offline   Send a Private Message Reply With Quote
Old 07-30-2010, 09:14 PM   #4
Snowweasel
Smokin 50HP Club
Snowweasel's Avatar
Smokin' Bucks $7.57
Default
I have ASR on mine ,But it says see manual for procedure,and I no longer have a manual
Snowweasel is offline   Send a Private Message Reply With Quote
Old 07-31-2010, 08:11 AM   #5
mulldriverAA
Smokin' Bucks $6.63
Default
Check Ebay for your manual
mulldriverAA is offline   Send a Private Message Reply With Quote
Old 07-31-2010, 03:26 PM   #6
vetteoz
Default
That was silly.
From what I am reading online there is a precise ASR setup procedure using a certain size drill bit to set the clearance
__________________
  • Submit Thread to Digg
  • Submit Thread to del.icio.us
  • Submit Thread to Facebook
  • Submit Thread to StumbleUpon
  • Submit Thread to MySpace
  • Submit Thread to Twitter
  • Submit Thread to Google
You may not post new threads
You may not post replies
Forum Jump
All times are GMT -8. The time now is 08:12 PM. Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2006-2009 © SmokinVette.Com
