SmokinVette.com Forums (http://www.smokinvette.com/corvetteforum/index.php)
-   C6 Scan & Tune (http://www.smokinvette.com/corvetteforum/forumdisplay.php?f=83)
-   -   When best time for tune? (http://www.smokinvette.com/corvetteforum/showthread.php?t=41580)
REHAB 06-02-2010 08:00 AM
Hotter months of summer? Or cooler months of winter? Your talking about a big difference in temperatures.
Ian@TheTuningSchool.com 06-02-2010 11:42 AM
You will get better hp and tq number if you were to tune it during the winter. But it you were to tune it during the summer the dyno should be able to give you a correction factor to a standard day.
Ian
BigDs_C6 06-24-2010 10:30 AM
If you get your own software or tuner, then you could build a tune for both.
D
Mike@Diablosport 06-24-2010 10:34 AM
The end result will be the same either way, but as mentioned, the numbers on a dyno will look better in the cool weather.
BigDs_C6 06-24-2010 10:40 AM
So Mike, your saying there wouldn't be any benefit to logging data and running the numbers if there's a significant difference in outside air temp compared to when you first made adjustments to a tune?
I thought for sure I'd have to retune mine in the fall/winter months.
D
FLVette 08-02-2010 06:27 AM
Isn't the main difference just the added wear the heat puts on the car. That the tune will still be good winter or summer?
Ian@TheTuningSchool.com 08-04-2010 09:27 AM
Yeah you will be good both winter and summer. You will just have a little better performance during the winter months.
Jeffster 08-06-2010 08:22 AM
Would the difference be noticeable?
StreetRacer 08-09-2010 08:39 AM
Won't it run rich during summer months then?
Antonio1988 09-04-2010 12:58 AM
Only when the motor gets really hot, at which point it will pull timing to protect itself
Powered by vBulletin® Version 3.8.4
