4L60E Build Up Thread From FLT
This thread was started on another forum and I wanted to share it with you guys here at SmokinVette.com. This thread will show you guys not only what we do here at FLT but give you guys an idea of what goes into a quality built transmission. The original thread started with a customer that came to our shop to pick up his new transmission and left with more than what he bargained for. Here is the original post from his thread with the tear down photo's of his transmission. http://www.ls1tech.com/forums/automa...-lot-pics.html I will add to the thread with the rest of the build up material that I have. Enjoy the reading! Vince
The beginning of assembly
Here are some pictures the beginning of the trans being assembled. The case has already been media blasted and all bores have been clean and polished with scotch bright. This first picture is of the case bushing installed.
http://i110.photobucket.com/albums/n...t/IMG_1529.jpg Here are a couple others. http://i110.photobucket.com/albums/n...t/IMG_1530.jpg http://i110.photobucket.com/albums/n...t/IMG_1521.jpg http://i110.photobucket.com/albums/n...t/IMG_1522.jpg Picture is of the low/reverse piston with the seals installed. http://i110.photobucket.com/albums/n...t/IMG_1532.jpg Picture with of the low/reverse piston, spring cage and snap ring. http://i110.photobucket.com/albums/n...t/IMG_1534.jpg Picture of the piston in the case ready to be installed. This is the tool that I use to lightly tap it into place. http://i110.photobucket.com/albums/n...t/IMG_1536.jpg This picture is with the piston in the case and the spring cage ready to be compressed. http://i110.photobucket.com/albums/n...t/IMG_1538.jpg This is the tool that is used to compress the spring cage. http://i110.photobucket.com/albums/n...t/IMG_1542.jpg This is how the spring cage is compressed in order to install the snap ring that retains the spring cage. http://i110.photobucket.com/albums/n...t/IMG_1545.jpg This is what it looks like when it is done. http://i110.photobucket.com/albums/n...t/IMG_1548.jpg More photo's coming of the assemblies being installed. Stay tuned and enjoy the pictures. Vince |
Here are some added photo's of the back half of the trans being assembled. The next step is to get the rear planet assembly ready and get it installed in the case. As you can see in the pictures in post my last post we have installed our low and reverse piston assembly. The next parts to look at are the rear ring gear and the ring gear support. This first picture is of the support. Note the condition of the bushing surface and also the splined area's of this part. They need to be like new in condition. If they are badly worn, we will replace it with another one. Here is the photo.
http://i110.photobucket.com/albums/n...t/IMG_1551.jpg The next piece is the rear ring gear. We make sure that this gear is clean and free of debris. The snap ring groove loves to collect debris. Some builders never take this apart. That is poor building practice IMO. We make sure to view and clean every part in these transmissions. Also making sure that the gear itself is not chipped or damaged in any way. Here is a photo of a ring gear ready to be installed. http://i110.photobucket.com/albums/n...t/IMG_1557.jpg Here is a picture of the two pieces assembled with the snap ring. http://i110.photobucket.com/albums/n...t/IMG_1566.jpg The next part to address after cleaning it in solvent is the rear planet. We inspect the gears for pitting, chips and looseness of the pinion gears. See where my fingers are, this is where the gear needs to be checked for looseness/wobble. Here is a picture of the planet. http://i110.photobucket.com/albums/n...t/IMG_1572.jpg The next photo is of the planet with the torrington bearing already installed. http://i110.photobucket.com/albums/n...t/IMG_1577.jpg Next is to assemble the planet and the ring gear assembly. http://i110.photobucket.com/albums/n...t/IMG_1580.jpg I always make sure to lightly grease bushing surfaces of hard parts and also the bushing itself. http://i110.photobucket.com/albums/n...t/IMG_1588.jpg The next step is to get the low reverse clutch pack ready to be installed. The wave plate is the first plate that will be installed into the case. This is followed with a steel and a clutch until all 5 plates are in the case. Here is a photo of the pack before it is installed. http://i110.photobucket.com/albums/n...t/IMG_1595.jpg Next we will install the planet assembly into the case. http://i110.photobucket.com/albums/n...t/IMG_1597.jpg Then the wave plate, steels and frictions are installed. http://i110.photobucket.com/albums/n...t/IMG_1599.jpg The following part is an anti-rattle clip. We as always inspect this clip to make sure that it has not collapsed and is like new in condition. Here is a picture of it. http://i110.photobucket.com/albums/n...t/IMG_1601.jpg I always grease this clip into place in the case. http://i110.photobucket.com/albums/n...t/IMG_1610.jpg The next part to be installed will be the low roller support. Here is the photo. http://i110.photobucket.com/albums/n...t/IMG_1611.jpg The next thing to do is to install new low roller and the snap ring to keep it in place. http://i110.photobucket.com/albums/n...IMG_1620-1.jpg The next step is to install the low roller race. This race has been modified for use with our FLT beast sun shell kit. http://i110.photobucket.com/albums/n...t/IMG_1628.jpg When fully installed this is what it looks like. http://i110.photobucket.com/albums/n...IMG_1630-2.jpg The next step is to install it into the case. Here is the photo of the complete low roller assembly assembled into the case. http://i110.photobucket.com/albums/n...t/IMG_1637.jpg Next step is to install the snap ring into the case. It is important that it be installed in the correct location. http://i110.photobucket.com/albums/n...t/IMG_1643.jpg Here a photo with the snap ring seated in the case and also the low roller seated on the planetary. http://i110.photobucket.com/albums/n...t/IMG_1646.jpg Next we will assemble our FLT/beast sun shell package. Vince |
The next step is to replace the rear sun gear bushing using a wide bushing for the beast sun shell. This is required to add support for the shell and is recommended by the manufacturer. I believe the reason is because the shell is heavier. Here is a picture to show the difference in the two bushings.
http://i110.photobucket.com/albums/n...t/IMG_1695.jpg I always look closely at the teeth of the gear (bottom) and also the splines that will be pressed into the the sun shell(top). They need to not show any signs of wear. Otherwise unacceptable gear train noise can occur. Here is a close up photo. http://i110.photobucket.com/albums/n...t/IMG_1701.jpg The next photo is of the stock beast shell. http://i110.photobucket.com/albums/n...t/IMG_1684.jpg Here is a photo to show you what happens to the factory shell. The OEM shell on the left is obviously broken. You can also see that the beast shell is much thicker in this area. http://i110.photobucket.com/albums/n...IMG_1658-4.jpg Here is a photo to show you what the oem washer looks like. This washer would normally be installed on the low roller race and would only be used with an oem shell. When using the beast shell it would be discarded. http://i110.photobucket.com/albums/n...t/IMG_1648.jpg Here is the photo with it on the race. http://i110.photobucket.com/albums/n...t/IMG_1649.jpg Here is a picture of the washer that is supplied with the beast shell. http://i110.photobucket.com/albums/n...t/IMG_1651.jpg Here is a photo with it the washer installed. We only use this setup on our level 3 builds. http://i110.photobucket.com/albums/n...t/IMG_1654.jpg On our level 4 and 5 builds we use a bearing instead of the washer. Here is a photo of what our FLT beast shell looks like with the bearing installed. http://i110.photobucket.com/albums/n...IMG_1692-2.jpg In order to install a bearing here it requires that we install a sleeve to support it. It also requires the low roller race be modified. Here is a photo of the sleeve for the shell. http://i110.photobucket.com/albums/n...IMG_1687-2.jpg Here is a photo of the factory race. http://i110.photobucket.com/albums/n...t/IMG_1649.jpg Here is a photo of our modified race. It has been decked and bored. http://i110.photobucket.com/albums/n...IMG_1624-1.jpg When it is all done we press the sun gear in and this is what gets installed next in our level 4 and 5 builds. http://i110.photobucket.com/albums/n...IMG_1705-1.jpg Here is the photo with our FLT beast shell installed. http://i110.photobucket.com/albums/n...IMG_1707-1.jpg I will post up some more photo's of the reaction shaft and output shaft differences to complete the rear half install. Feel free to post a question or a comment here in this thread. Stay tuned. Vince |
Here are the remaining photo's of the rear half of the transmission assembly. I believe we left off with the FLT beast shell being installed.
http://i110.photobucket.com/albums/n...IMG_1707-1.jpg The next piece in the trans for us to look at is the reaction shaft. There are two different styles for these transmissions. The first style is the washer style which in this next photo is piece on the right. The piece on the left is the bearing style. I prefer the bearing style and it is a mandatory piece in all of our level 5 builds. Theses pieces have been polished and are ready for inspection. I look closely at the splined areas of these parts to look for wear and must be like new in order to be used. The bushings in these parts are in most cases are replaced. These bushing are still the originals. Here is the photo. http://i110.photobucket.com/albums/n...IMG_1675-2.jpg Next we will inspect the front ring gear for wear. The area where the reaction shaft and the snap ring is installed love to collect dirt and debris. It is good practice to make sure that the part is not only good to use but is also very clean. We also want to make sure that the area where the 3-4 clutch rides is in good condition as well. Here is the photo. http://i110.photobucket.com/albums/n...IMG_1716-2.jpg The next step is to assemble the reaction shaft and the front ring gear. Note that the bearing and the snap ring have already been installed in it's proper location. Here is the photo. http://i110.photobucket.com/albums/n...IMG_1721-1.jpg If you were not using the bearing style reaction shaft. The washer that would be used instead would be installed and greased here. http://i110.photobucket.com/albums/n...IMG_1713-2.jpg The next step is to inspect the front planet. Once again we need to look at the splines of the part where the output shaft will ride. Also the pinion gears need to be inspected for looseness/wobble and pitting. Here is a photo of the front planet. http://i110.photobucket.com/albums/n...IMG_1722-2.jpg I always make sure to apply some assembly grease to the areas where bushings will ride. Also I will apply grease to the bushings themselves. http://i110.photobucket.com/albums/n...t/IMG_1726.jpg http://i110.photobucket.com/albums/n...t/IMG_1728.jpg Here is the photo of the planet and reaction shaft assembled. http://i110.photobucket.com/albums/n...t/IMG_1732.jpg Here is the photo of the full assembly being installed. http://i110.photobucket.com/albums/n...IMG_1733-2.jpg Now we are ready to install our output shaft. Here is the photo. http://i110.photobucket.com/albums/n...IMG_1735-2.jpg Here is a photo of the output shaft for a 2wd vehicle. It has been polished and is ready to go. http://i110.photobucket.com/albums/n...IMG_1737-2.jpg Note the location of the snap ring groove and also the surfaces where the bushing will ride. They are in perfect condition. Here is the photo. http://i110.photobucket.com/albums/n...IMG_1740-2.jpg The next step is to install the output shaft and install the snap ring. Here is the photo. http://i110.photobucket.com/albums/n...IMG_1744-2.jpg After all pieces are in place, I make sure to grease the area where the front sun gear bushing will ride. http://i110.photobucket.com/albums/n...IMG_1745-2.jpg Here it is, the rear half of the trans is now built. http://i110.photobucket.com/albums/n...IMG_1746-2.jpg I hope you guy's are enjoying the photo's. Feel free to post a comment or a question here. I will start the next portion of the front assemblies here here shortly. Vince |
The beginning of the front half being installed.
I am starting the build of the front half of the transmission. Refer to my last post to see where we left off. This next set of photo's is going to show how we build our input drums in our level 4 and 5 units. This will be a segment on how each and every sleeved drum gets done here at FLT. This drum in my opinion is a very good upgrade and makes this trans much stronger. The idea behind the sleeved drum is that it will keep the aluminum drum from expanding and not allowing the input shaft to float in the drum. We have seen this many times in the past and also in cores that we tear down. Most shops never remove these shafts and for us it is mandatory. This is a picture of where we left off.
http://i110.photobucket.com/albums/n...t/IMG_2882.jpg Here are some photo's of the drum completely disassembled. All surfaces have been inspected, cleaned and critical surfaces have been polished ready for assembly. http://i110.photobucket.com/albums/n...t/IMG_2401.jpg http://i110.photobucket.com/albums/n...t/IMG_2365.jpg We always pay close attention to the surfaces where the input shaft will be pressed in and also that all splined areas are acceptable. This first picture is where the shaft will be pressed in. http://i110.photobucket.com/albums/n...t/IMG_2398.jpg Here is a photo of the area where the reverse input clutches will ride. Also note the area where the feed holes will be aligned and the quality of the surface. http://i110.photobucket.com/albums/n...t/IMG_2375.jpg Now we take a look at the inside of the drum. We are looking for bad ridges where the steels will ride. Slight wear marks are ok and in most cases the drum is reusable. Here is a photo of the inside of the drum. http://i110.photobucket.com/albums/n...t/IMG_2365.jpg Here is the pieces that will be installed next. They include the drum, sleeve and the input shaft. http://i110.photobucket.com/albums/n...t/IMG_2410.jpg Now we are ready to install the sleeve in our drum. The first thing to do is to apply a thin layer of lock tight to the drum and the sleeve. Then line up the lube hole slot for the overrun clutch. Here are a couple photo's. http://i110.photobucket.com/albums/n...t/IMG_2414.jpg http://i110.photobucket.com/albums/n...t/IMG_2415.jpg Now that we have the sleeve in place it is time to put it in the press. In most cases the arbor press will work for the install of the sleeve. If not we have larger press that works as well. I will make sure to support the drum when pressing on the sleeve. This will assure us that it will not get cracked or stressed during the process. Here is a photo of the setup on the press. http://i110.photobucket.com/albums/n...t/IMG_2422.jpg After getting things lined up, I use an old bearing race to press the new sleeve on the drum. http://i110.photobucket.com/albums/n...t/IMG_2430.jpg http://i110.photobucket.com/albums/n...t/IMG_2434.jpg Then we press the sleeve down. They go on with quite a bit of resistance and that is what we are after. Here are a couple photo's of the sleeve being pressed on. One from the top. http://i110.photobucket.com/albums/n...t/IMG_2440.jpg Another that I got a little creative with. Thought it was a cool picture. http://i110.photobucket.com/albums/n...t/IMG_2446.jpg The drum is now sleeved. Here is the photo. http://i110.photobucket.com/albums/n...t/IMG_2457.jpg Next we will install the shaft. |
The input shaft being installed with the Teflon seals
Here we are going to make sure to line up the splines for the input drum an the shaft. Notice the double wide spline that centers things.
http://i110.photobucket.com/albums/n...t/IMG_2409.jpg http://i110.photobucket.com/albums/n...t/IMG_2407.jpg http://i110.photobucket.com/albums/n...t/IMG_2403.jpg Next we will use a light amount of lock tight on the area where the feed holes are on both the shaft and the drum. Also put a good bead on the splines of the shaft itself. http://i110.photobucket.com/albums/n...t/IMG_2461.jpg http://i110.photobucket.com/albums/n...t/IMG_2478.jpg Next it will be time to put the shaft in the hole of the drum. Making sure to line it up properly and then tap it down with a rubber mallet or plastic dead blow hammer. It should not go in very far and we are just making sure that there is proper resistance at this point and also that it is seated properly/aligned. http://i110.photobucket.com/albums/n...t/IMG_2479.jpg Now we will head to the press. Once again using a large socket to support the drum to avoid any chance of cracking or stressing it. Here are a few photo's of the setup. http://i110.photobucket.com/albums/n...t/IMG_2482.jpg http://i110.photobucket.com/albums/n...t/IMG_2485.jpg http://i110.photobucket.com/albums/n...t/IMG_2488.jpg The shaft is now installed and here are a few photo's of the finished product of the sleeved drum. http://i110.photobucket.com/albums/n...t/IMG_2494.jpg http://i110.photobucket.com/albums/n...t/IMG_2501.jpg http://i110.photobucket.com/albums/n...t/IMG_2855.jpg Next we will install the input shaft Teflon seals. These are done by the use of a seal installer and a resizer. Here are some photo's of them being installed and then sized. http://i110.photobucket.com/albums/n...t/IMG_2856.jpg http://i110.photobucket.com/albums/n...t/IMG_2861.jpg http://i110.photobucket.com/albums/n...t/IMG_2863.jpg http://i110.photobucket.com/albums/n...t/IMG_2865.jpg http://i110.photobucket.com/albums/n...t/IMG_2869.jpg http://i110.photobucket.com/albums/n...t/IMG_2873.jpg http://i110.photobucket.com/albums/n...t/IMG_2875.jpg I will next do the assembly of the clutches, steels, pistons, spring cages and the input sprag. Stay tuned and enjoy the photo's. Vince |
In my last post we left off at the input drum being sleeved and the input shaft being pressed back in the drum. These next photo's will be of the internal pistons, retainers, modified spring cages, seals and 3-4 clutch apply ring being installed.
This first picture is of the sleeved drum ready for the assembly of the internal components. http://i110.photobucket.com/albums/n...IMG_2855-1.jpg http://i110.photobucket.com/albums/n...t/IMG_2501.jpg The first steps that we take are to install the internal seals of the drum. Here are the ones that I am referring to. The top one is the new 3-4 steel bonded apply piston. Bottom left is a oring that seals the forward clutch housing and also the new 3-4 clutch piston. Bottom right seal is a seal used for lube oil from the input shaft to the output shaft. Here is a photo of the seals. http://i110.photobucket.com/albums/n...y/IMG_2520.jpg Here is a photo of the lube seal for the two shafts. It gets installed in the input drum here. http://i110.photobucket.com/albums/n...y/IMG_2503.jpg http://i110.photobucket.com/albums/n...y/IMG_2506.jpg The next seal that I will install is the green oring. Here is where it will be installed. http://i110.photobucket.com/albums/n...y/IMG_2509.jpg The new 3-4 clutch apply piston is the next to be installed. Here are a couple of photo's. http://i110.photobucket.com/albums/n...y/IMG_2524.jpg http://i110.photobucket.com/albums/n...y/IMG_2525.jpg Next we will install a modified seal installer. This installer has been bored to accommodate for the steel sleeve that we have installed. http://i110.photobucket.com/albums/n...y/IMG_2528.jpg Here is a line up of the components that will be assembled into the input drum. http://i110.photobucket.com/albums/n...y/IMG_2575.jpg The next step that I will do is to get our spring cages ready to be installed. These are the cages that we will modify with the use of springs from transgo. The idea with these springs is that they are heavier and also will greatly reduce any centrifugal apply at high rpms with the 3-4 clutch/overrun clutch. Here are the factory cages. http://i110.photobucket.com/albums/n...y/IMG_2580.jpg As you can see in this photo the 3-4 return spring cage is held together with little hooks. They will need to be bent out of the way in order to get it apart and remove the factory springs. Here are a few photo's. http://i110.photobucket.com/albums/n...y/IMG_2582.jpg http://i110.photobucket.com/albums/n...y/IMG_2586.jpg http://i110.photobucket.com/albums/n...y/IMG_2592.jpg Here is a photo of the overrun/forward return spring cage. I will first remove the bottom of the cage using a small screw driver. Then I will use a pair of wire cutters to remove the springs from the top portion of the cage. http://i110.photobucket.com/albums/n...y/IMG_2587.jpg Here is a photo of both cages fully apart with the new springs that we are going to install. http://i110.photobucket.com/albums/n...y/IMG_2607.jpg Here are photos of the 3-4 cage and it's new springs. Note the first picture the springs are tapered and will snap in place. http://i110.photobucket.com/albums/n...y/IMG_2608.jpg http://i110.photobucket.com/albums/n...y/IMG_2617.jpg To be continued............ |
Time for the clutches and sprag install
In this next portion of the thread we will be installing the clutches in the input drum. We left off with the internal pistons being installed along with the modified spring cages. Here is a picture as to where I left off.
http://i110.photobucket.com/albums/n...m/IMG_2695.jpg The first things to do now are to install the input drum to sprag bearing and put a little assembly lube on the seal for the lube circuit connecting the input drum to the output shaft. Here are some photo's. http://i110.photobucket.com/albums/n...ofIMG_2701.jpg http://i110.photobucket.com/albums/n...m/IMG_2702.jpg http://i110.photobucket.com/albums/n...m/IMG_2696.jpg Now it is time to install the overrun clutches, steels and also the backing plate which also acts as the apply plate for the forward clutch. The line up of these parts will start with a steel, clutch, steel, clutch and then the backing plate. Here is the line up of these parts outside of the drum. http://i110.photobucket.com/albums/n...m/IMG_2703.jpg This first picture has the first overrun steel installed. http://i110.photobucket.com/albums/n...m/IMG_2705.jpg Then we will install the first clutch and repeat the process. http://i110.photobucket.com/albums/n...m/IMG_2709.jpg http://i110.photobucket.com/albums/n...m/IMG_2710.jpg http://i110.photobucket.com/albums/n...m/IMG_2712.jpg And then finish up with the backing plate. http://i110.photobucket.com/albums/n...m/IMG_2713.jpg At this point the wave plate can be installed for the forward clutch. This plate is designed the way it is to absorb some of the shock of the apply of the forward clutch. Here are a couple photo's of it. http://i110.photobucket.com/albums/n...m/IMG_2715.jpg And one with it installed in the drum. http://i110.photobucket.com/albums/n...m/IMG_2717.jpg Next we will get our input sprag assembly together. It will have have the sun gear for the front planet with the bushing already installed. The sprag race surfaces carefully inspected to be in good condition. The sun gear will also be inspected for pitting or abnormal wear. If any of these pieces do not meet our criteria they are replaced. A new Borg Warner sprag is also installed at this point and time. Here are a few photo's of the assembly as it goes together. http://i110.photobucket.com/albums/n...m/IMG_2721.jpg http://i110.photobucket.com/albums/n...m/IMG_2730.jpg http://i110.photobucket.com/albums/n...m/IMG_2734.jpg http://i110.photobucket.com/albums/n...m/IMG_2736.jpg Also once all the pieces are installed and the snap ring that keeps it together is in place, I will lube the bushings. http://i110.photobucket.com/albums/n...m/IMG_2749.jpg Now the sprag assembly is complete and can be installed in the drum. http://i110.photobucket.com/albums/n...m/IMG_2763.jpg The next step will be to get the forward clutch assembly ready and installed. |
| All times are GMT -8. The time now is 02:31 AM. |
Powered by vBulletin® Version 3.8.4
