When best time for tune? - SmokinVette.com Forums
post #1 of 10 (permalink) Old 06-02-2010, 09:00 AM Thread Starter
REHAB's Avatar
Question When best time for tune?
Hotter months of summer? Or cooler months of winter? Your talking about a big difference in temperatures.
2008 C6 Corvette Convertible
"The difference between perseverance and obstinacy is that one often comes from a strong will, and the other from a strong won't."
REHAB is offline
post #2 of 10 (permalink) Old 06-02-2010, 12:42 PM
Ian@TheTuningSchool.com's Avatar
You will get better hp and tq number if you were to tune it during the winter. But it you were to tune it during the summer the dyno should be able to give you a correction factor to a standard day.
Ian
www.thetuningschool.com sales, support, research and tuner 727-264-8875
2008 Corvette A6 1 7/8 kooks catted headers, air raid intake, ported TB, NPP exhaust and tuned with HP tuners. 425hp/428tq
Ian@TheTuningSchool.com is offline
post #3 of 10 (permalink) Old 06-24-2010, 11:30 AM
BigDs_C6's Avatar
If you get your own software or tuner, then you could build a tune for both.
D
BigDs_C6 is offline
post #4 of 10 (permalink) Old 06-24-2010, 11:34 AM
Smokin Tuner
The end result will be the same either way, but as mentioned, the numbers on a dyno will look better in the cool weather.
Mike@Diablosport is offline
post #5 of 10 (permalink) Old 06-24-2010, 11:40 AM
BigDs_C6's Avatar
So Mike, your saying there wouldn't be any benefit to logging data and running the numbers if there's a significant difference in outside air temp compared to when you first made adjustments to a tune?
I thought for sure I'd have to retune mine in the fall/winter months.
D
BigDs_C6 is offline
post #6 of 10 (permalink) Old 08-02-2010, 07:27 AM
FLVette's Avatar
Isn't the main difference just the added wear the heat puts on the car. That the tune will still be good winter or summer?
FLVette is offline
post #7 of 10 (permalink) Old 08-04-2010, 10:27 AM
Yeah you will be good both winter and summer. You will just have a little better performance during the winter months.
post #8 of 10 (permalink) Old 08-06-2010, 09:22 AM
Jeffster's Avatar
Would the difference be noticeable?
My Toybox:
2007 C6 Corvette
2003 Ford Mustang GT
1998 Ford Mustang GT (Sold)
Jeffster is offline
post #9 of 10 (permalink) Old 08-09-2010, 09:39 AM
StreetRacer's Avatar
Won't it run rich during summer months then?
My Vette:
2006 6 Speed Coupe, 1st owner: Magnuson 112, LG Headers, Callaway Honker, AFR 225 Heads, Comp Cam, 170 thermostate, Nitto Invo's, Borla Stinger cat back
StreetRacer is offline
post #10 of 10 (permalink) Old 09-04-2010, 01:58 AM
Antonio1988's Avatar
Only when the motor gets really hot, at which point it will pull timing to protect itself
Antonio1988 is offline
