Tune options for '08 C6 LS3 - SmokinVette.com Forums
post #1 of 6 (permalink) Old 01-25-2010, 06:35 AM Thread Starter
I want to push the easy button to 11's on a near stock '08 C6 LS3 "mn6" Is a tune required for a 100 horse dry nitrous ? supporting mods are K&N fipk cold air kit & Corsa Sport axlebacks.
If a tune is needed should I go Predator or custom dyno-tune ?
2007 Chevrolet Impala SS V8 "DD"
2004 Single Turbo 350Z - SOLD !!!
2003 ProCharged Mach1 - SOLD !!!
WeeZee is offline
post #2 of 6 (permalink) Old 01-25-2010, 07:01 AM
Smokin Tuner
A tune is going to be needed for sure, at the minimum you'll want to pull a little timing for that 100 shot, and you can do that with the Predator or Trinity easily.
Thanks
Mike
Mike@Diablosport is offline
post #3 of 6 (permalink) Old 01-25-2010, 08:09 AM Thread Starter
cool what about the skip shift. Can u take this dumb sh*t off with your Predator.
WeeZee is offline
post #4 of 6 (permalink) Old 01-25-2010, 02:06 PM
06MonteSS's Avatar
Send a message via AIM to 06MonteSS Send a message via MSN to 06MonteSS Send a message via Yahoo to 06MonteSS
yes, the CAGS/skip-shift is eliminated in the tunes...
06MonteSS is offline
post #5 of 6 (permalink) Old 01-26-2010, 09:54 PM
bullitt4110's Avatar
personally I would get a dyno tune with any power adder just to make sure the air/fuel is in check and you are not getting any knock. That way you would be able to get the full potenial out of the nitrous and to make sure that the nozzle placement is set-up properly, the dry nozzles placement can be tricky sometimes.
2001 Quicksilver Z06 - 383ci - A&A Vortech
1979 Silver C3 - Stock
bullitt4110 is offline
post #6 of 6 (permalink) Old 01-27-2010, 11:20 AM
Smokin Tuner
Yikes...I did not see the dry part mentioned....oops.
Yeah, even with the pred or Trinity, I'd dial it in on the dyno, or better yet, start with a wet kit!!
