Corvette Floor Pans For 1975-1982 - SmokinVette.com Forums
post #1 of 1 (permalink) Old 09-01-2010, 11:50 AM Thread Starter
Corvette Floor Pans
If you have restored or are restoring a 1975-1982 Corvette you most likely have had to deal with rust issues in your floor pans. Rusted floor pans are a major problem with 1975-1982 Corvettes. In 1975, GM decided to install steel floor pans instead of the previously used fiberglass floor pans, most likely to cut down interior noise and heat. The problem with the steel floor pans, of course, is when they are exposed to water for long periods of time; they rust. If you have been around or worked on many 1968-1982 era Corvettes then you probably know that they are prone to leaking and rusting around the windshield frame and t-tops. Replace the windshield frame to fix the source of the problem. Over time the water makes its way down into the floor where it sits under the carpet and rusts the floor pans. You can try to patch smaller rust holes but often times the only solution is to completely replace the damaged floor pans.
We now offer brand new 1975-1982 Corvette Floor Pans so you do not have to worry about finding a donor car to cut set out of yourself. Our Corvette floor pans are designed to be welded in the rear and sides while the front is riveted in place as original. During the installation you will be able to keep your Corvette’s original transmission and driveshaft tunnel. These new floor pans are correctly made for either 75-77 or 78-82 where previously there was only one style available for all 75-82. Just one more way we are making your Corvette restoration as perfect as possible.
Purchase online at Zip Corvette Parts
Read more Corvette Parts news...
Paul@Zip is offline
