C6 Corvette DiabloSport Predator Programmer & Tuner - SmokinVette.com Forums
post #1 of 1 (permalink) Old 04-26-2010, 10:10 AM Thread Starter
Corvette Predator Programmer
The C6 Corvette DiabloSport Predator Programmer is a state-of-the art, high performance tuning flash programmer in a sleek handheld design. Once connected to your C6, Z06, or Grand Sport Corvette, the Predators internal computer recognizes the PCM and automatically picks the proper tuning files designed specifically for that PCM. Inside the Predator’s memory are the actual tuning files that optimize spark timing and air/fuel ratio curves. Unlike other “tuners”, the DiabloSport Predator programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and more predictable power delivery. DiabloSport engineers spend many hours on the dyno, street, and track to ensure the tunes provided with the Predator are the best they can possibly be for your Corvette.
Installing a DiabloSport tune on your Corvette using the Predator Programmer is simple and only takes a few minutes. You should know that the very first time the predator is used on your Corvette it will automatically create a backup of the original factory tune. If your Corvette has previously been tuned you should proceed with caution as serious engine damage can occur if the Predator tune is installed over a non-factory or aftermarket tune. We recommend having a Chevrolet dealer reflash your Corvettes ECU (Engine Control Unit) to its original settings so there will be no possibility of damage to your Corvette.
Before starting to install the tune be sure that your Corvette is parked and the engine is off. All doors must be closed and all electrical accessories must remain off. To install the tune, plug the Predator into the diagnostic port. The predator will recognize the vehicle and then give the options of performance tune, diagnostics, or options; select performance tune by pressing the continue key. After reading the disclaimer you can now turn the ignition on being sure not to start the vehicle. Next highlight the type of tune you would like to install and follow all prompts to turn the ignition on and off. While the tune is being written, be sure not to interrupt the process or ECM damage can occur. Once completed, you simply unplug the Predator and cycle the key to start your Corvette’s engine. The predator also contains several DiabloSport tunes that have been tested and approved by their engineers. You can install your choice tune as is or you may customize the tune to meet your wants and needs.
If you are planning on having your Corvette serviced it is recommended that you restore your Corvette back to the stock tune. This can be done at any time using the restore feature on the Predator. No need to worry if you have customized the tune as it will be saved for future use.
All C6 Corvette DiabloSport Predator Programmers come with a manufacturers two year warranty that covers defects in materials or workmanship. Be sure to Register Your Predator Programmer to take advantage of the warranty as well as other benefits including tech support, software update notifications, product benefits, monthly giveaways and more.
Tuning Paramaters:
Cooling Fan – On/Off TemperaturesRev LimiterMultiple Fuel Adjustment PointsShift Points – RPM Full ThrottleMultiple Timing Adjustment PointsShift Points – MPH (Up/Down)Injector Adjustment – Injector Size/LT Fuel TrimsShift Pressure – part ThrottleRear O2 Sensors – EGR On/Off (Race Use Only)Fuel Table – AdjustmentTorque Modulation On/Off Per GearGlobal SparkMAF Curve – AdjustmentIdle – AdjustmentTiming Table – AdjustmentShift PressureTorque Management – On/OffShift TimingTraction Control – On/OffSpeed Limiter
DiabloSport Predator Features:
Will Not Void Factory WarrantyInternet UpdatableDiagnostics – Read & Erase Fault CodesData MonitoringLarge Backlit displayData LoggingHolds Up To Five Custom TunesPerformance Calibrations30+ Horsepower GainsFree Firmware Updates
Purchase online at Zip Corvette Parts
Read more Corvette Parts news...
Paul@Zip is offline
