My Corvette 2008 z51, keeps telling me to check coolant level. The C6 does not have a coolant sensor but it is determined based on a software algorithm tho. The car is stock
I've done everything I disconnected the positive and negative battery cables from the battery and touch the cable ends together for 60 seconds then connect the battery cables back to the battery but it did not work.
They said if that did not work I need to replace HVAC control head but I didn't do that.
I have checked the radiator and the cooling fan to see if it was dirty or had any problems but it was good.
I also replaced the old coolant level with new coolant and filled it to the proper cool max level.
Can someone help me out?
