C6 Corvette Resetting Windows after Battery Disconnect-Easy - SmokinVette.com Forums
post #1 of 1 (permalink) Old 07-08-2008, 08:25 AM Thread Starter
ShockerRacing.com's Avatar
Send a message via AIM to ShockerRacing.com
This is straight from the owners manual:
This is the procedure the owner's manual says you should use to reindex the window. When your windows will not go back up after closing your door this is the procedure to follow from the owners manual. This will need to be done anytime the battery is disconnected.
Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done.
This is called resetting of the window indexing or power window initialize and is in the owner's manual. See page 2-18 of the 2006 owner’s manual, or page 87 of the 2007 owner’s manual.
www.shockerracing.com for more C6 Install Write-ups
ShockerRacing.com is offline
