new carpet - SmokinVette.com Forums
post #1 of 9 (permalink) Old 12-31-2012, 01:10 PM Thread Starter
kisuke's Avatar
new carpet
hello,
id like to redo the the carpet in my vette and id like to know the most cost efficient way to do this seeing as my funds are low do to my age..
kisuke...
kisuke is offline
post #2 of 9 (permalink) Old 12-31-2012, 01:16 PM
bite the bullet and buy the pre-fitted sets...nothing you try to cut in .. will look as good ....http://www.ecklerscorvette.com/corve...loop-1976.html http://www.ecklerscorvette.com/corve...pile-1976.html
post #3 of 9 (permalink) Old 01-01-2013, 07:30 AM
minkus316's Avatar
Have you or would you do an underlayment or soundproofing?
http://www.ecklerscorvette.com/corve...1968-1977.html
minkus316 is offline
post #4 of 9 (permalink) Old 01-01-2013, 01:48 PM Thread Starter
kisuke's Avatar
yes
thanks guys and also i figure since there is already an underlay in the car i would just try to change the carpet but if i remember correctly there is a bit of glue holding them together so thanks for the links
kisuke is offline
post #5 of 9 (permalink) Old 01-01-2013, 03:42 PM
new carpet
I no u have not got heaps of money but definatly worth putting some sound deadner while doing it u will only come back some time later and do it.take your time and do right first time
75 targa is offline
post #6 of 9 (permalink) Old 01-05-2013, 07:35 AM
I think most of the good carpets come with a heat deflector layer too but you might consider adding one if not. Not sure if yer '77 has same cabin heat issues as older ones but if so, u can sure use the help.
buster is offline
post #7 of 9 (permalink) Old 01-09-2013, 05:12 PM
gbwright's Avatar
Did it in my 73, two things, add the sound and heat barrier, not that expensive, AND, be sure to protect the door post as you put the seats back in-can screw up the paint.
gbwright is offline
post #8 of 9 (permalink) Old 01-10-2013, 06:38 AM
Post
Get carpeting that is molded and not the cheap ones with sewn seams. Tried that on a previous car and it was a disaster. Get the molded carpets!
post #9 of 9 (permalink) Old 01-10-2013, 08:39 AM
chav73's Avatar
trust quality carpet venders. I have heard of bad experiences with carpet not fitting the application. I used Willcox and they were awesome, as with everything else that was purchased from them. I am a big fan of them. ordered the jute padding for the front of the cabin only. Dynamat was expensive. I was once told that you could go to a home improvement store and get the insulation (foil) that they sold there. Did not do that, however. Yes, premolded is best.
86 (sold) 86 (sold) 94 (sold) 00 (sold) 73 (kept) 07 (sold)
chav73 is offline
