71 vet noisy exhaust - SmokinVette.com Forums
post #1 of 5 (permalink) Old 11-25-2012, 11:34 AM Thread Starter
kenny k's Avatar
I put in a new motor, fired it up , and I hear a clanging sound coming from driver side exhaust , sounds like a bolt fell down the exhaust pipe. I unbolted every thing and reassembled it. Still hear the clanging , when I hit the exhaust pipes on the passenger side it sounds solid no problem, but when I tap on the driver side I hear the clanging , I have looked at it and nothing seems to be hitting anything, I unbolted the exhaust and inserted magnets vacuum hoses to see if there is a nut or bolt inside and came up empty handed.I am thinking maybe the muffler has a loose baffle or something if I hit the exhaust with my hand right under the header I hear the clang. It's got me baffled no pun intended. Any ideas what this can be? Also when the car idles there's no clanging but when I rev the motor I hear the noise.Thanks K.K.
kenny k is offline
post #2 of 5 (permalink) Old 11-25-2012, 01:25 PM
its probably that 9/16 inch wrench you can t find..LOL! ... take the muffler off and shake it ,see if it makes the clank
post #3 of 5 (permalink) Old 11-25-2012, 04:31 PM
It's not at all unusual for the internal pipes or baffles to break loose inside a muffler and rattle around. The only way to be reasonably sure is thump on the muffler itself.............
post #4 of 5 (permalink) Old 11-26-2012, 11:14 AM Thread Starter
kenny k's Avatar
Thanks , my muffler is welded on so I guess I'm going to hack saw it off and go from there.
kenny k is offline
post #5 of 5 (permalink) Old 11-26-2012, 01:01 PM
I ended up making my own mufflers using 2-1/2" tubing thruout. Yes, it was a LOT of work but they came out fantastic. About $100 for the pair and three days of my time...............
