Buying a Vette Common C3 Problems 1975-80 - SmokinVette.com Forums
post #1 of 32 (permalink) Old 08-14-2010, 12:22 AM Thread Starter
leonidman's Avatar
I'm thinking of buying a 1975-80 C3 and knowing nothing about these cars, what should I be on the look out for? Common rust areas, wiring issues etc.
Thanks a bunch
Jerry P
leonidman is offline
post #2 of 32 (permalink) Old 08-14-2010, 01:29 AM
VetteAholic's Avatar
Let's see what I can think of from the top of my head. The newer and less mileage the better. You may run into some eletrical problems in your dash. Radio not working, dimmer switch not working. You may run into vacuum issues, the pop up lights won't go up. The carb may or may not give you issues. Your brake calipers may start to leak. Rust may be all around the chassis, some will be minor rust, some not so minor . Though some Stingrays are in way better condition than others. Wait and see what another member will say. Hope I could be of help and Welcome to SmokinVette!!!
Vettes:
1974 Stingray, (SOLD) My first Corvette.
1992 Coupe,(SOLD, 7 optisparks later.)
2007 Coupe daily driver, (Financing!)
Mods: K&N intake, Full catless exhaust, Kooks 1 3/4. Tuned by DSMLIGHTS.
Wave to a fellow Corvette Owner
Contact me VIA Facebook: Facebook.com/VetteAholic
Check out Facebook Group "Florida Corvette Owners"
VetteAholic is offline
post #3 of 32 (permalink) Old 08-14-2010, 04:10 AM
abike's Avatar
Vetteaholic pretty much covered it.You either want a vette or you don't.Even the best looking vets have problems so treat it likeany car and decide if you really want it, then ask your self is it worth the price for what is right or wrong with it,If you answer yes then enjoy the good and the bad and make it your vette. GOOD LUCK either way.
abike is offline
post #4 of 32 (permalink) Old 08-14-2010, 04:43 AM
m37brat's Avatar
I think the best advice is don't think of it as an investment. If you are buying the car because you love it and want to enjoy and drive it, any thing can be fixed. Any Corvette is a car that almost any part can be bought or restored.
Here is proof that with a little hard work and more money than sense you can basically build one from the bottom up. Because of my stage of my life I may never actually finish my C3 but I always knew that the objeect was the car but the journey.
The Never Ending Story
Welcome to SV and enjoy the hunt and when you get your dream car remember to save the wave......
__________________________________________________ _______________________
My Heroes Wear Combat Boots
If feel you can not stand behind our troops, please feel free to stand In Front Of Them!!!!!
http://www.iraqwarheroes.com/
m37brat is offline
post #5 of 32 (permalink) Old 08-14-2010, 06:42 AM
Glad you brought it up, I went over and checked it out, awesome topic It really sucks that parts were gone due to the attack. But what I read was really nice .
Vettes:
post #6 of 32 (permalink) Old 08-14-2010, 08:01 AM
What To Look For
If the C3 has been garaged most of the time it won't have any serious rust issues. Only those that have remained outside will have rust issues, or those that come from states that salt their roads. Other than that, you may encounter bad electrical connections here and there. And caliper leakage is very normal. High mileage C3's will probably need new u-joints and will need to have the rear spindle bearings re-packed. It's nothing unusual to see fiberglass blistering on the very early C3's. My '82 is still in remarkable shape with 270,000 miles on it.
post #7 of 32 (permalink) Old 08-14-2010, 05:56 PM Thread Starter
leonidman's Avatar
Thanks all for the replys.
I was looking at an add for a C3 that stated "the frame under the seats was whole and not rusted in half that was common with these cars."
I had a '80 Camaro that the frame was rusted above the rear axle, which later I found was common for them. This is what I was referring to.
Electrical and vacuum problems I can handle as well as most repairs and maintenance, grew up poor and had to work on my own cars as many others have also. I can do most of the work except for transmission rebuild and engine cylinder wall boring.
JerryP
post #8 of 32 (permalink) Old 08-14-2010, 06:24 PM
the most common problem with neglected cars is rust in the windshield frame area and hinge pillar ..everything else is just as any other classic car..most anything you need for them is still available from several vendors...let us know if you buy one, we will be glad to assist .
post #9 of 32 (permalink) Old 08-16-2010, 10:49 AM
2_Late_I_Won's Avatar
An issue with mine is the rear tires seem to burn off LOL But as everyone else stated I agree Also the (this is more cosmetic) clocks usually wont work and the visor elbow will break or fall down.
2_Late_I_Won is offline
post #10 of 32 (permalink) Old 08-16-2010, 12:51 PM
dochorsepower's Avatar
OK, I'll add my 2 cents of experience from my 260,000 mile '75. Brakes are common, most guys have replaced with stainless sleeves. Electrical, engine compartment cowling harness can abrade and short out, that will have you scratching your head for awhile. Rear wheel bearings and u-joints are common replacement. Headlight actuators can be a problem, there are now some good seals made that cure the problem without replacing the complete unit. Front cross-member weld cracking, I've had mine fully welded and gusseted.
Good luck and enjoy.
dochorsepower is offline
