2006 GTO vs 2002 Z06 Corvette? - SmokinVette.com Forums
post #1 of 16 (permalink) Old 01-26-2008, 08:17 AM Thread Starter
Z Master's Avatar
Question 2006 GTO vs 2002 Z06 Corvette?
I have a friend with a stock '06 GTO who talks alot of game. I was curious on what others thought on this one? I have a few mods his is stock, the GTO is heavier (??), but nearly 4 years newer.
I think I could take him but don't want to embarrass myself and have to live with his sh*t about beating me?
What you all think?
Z Master is offline
post #2 of 16 (permalink) Old 01-26-2008, 02:42 PM
Disturbed's Avatar
Did A little research for you. This is all information based on stock Automatics.
I think you got him. Stats show you got him 0-60, 0-100, Quarter mile, and Top speed. I guess its all up to your abilities now. No guts no glory.
2006 Gto Specs
Performance Data
Performance Acceleration (0-60 mph): 5.5 sec. Braking Distance (60-0 mph): 128.96 ft. Base Number of Cylinders: 8 Base Engine Size: 6 liters Base Engine Type: V8 Horsepower: 400 hp Max Horsepower: 5200 rpm Torque: 400 ft-lbs. Max Torque: 4000 rpm Maximum Towing Capacity: 1000 lbs. Drive Type: RWD Turning Circle: 36.1 ft.
As it was in the beginning, performance is at the heart of the Pontiac GTO. A 6.0-liter LS2 V-8 produces an impressive 400 horsepower (298 kw) and 400 lb.-ft. of torque (542 Nm). The Hydra-Matic 4L65-E four-speed electronically controlled automatic transmission is standard, while a six-speed Tremec T56 manual transmission is optional. The awesome powertrain is capable of propelling the GTO form 0-60 in 4.7 seconds and 13-second quarter mile times.
TOP SPEED 160 MPH!
2002 Z06 specs (Stock)
Performance Acceleration (0-60 mph): 4.3 sec. Braking Distance (60-0 mph): 110 ft. Base Number of Cylinders: 8 Base Engine Size: 5.7 liters Base Engine Type: V8 Horsepower: 405 hp Max Horsepower: 6000 rpm Torque: 400 ft-lbs. Max Torque: 4800 rpm Drive Type: RWD Turning Circle: 42.3 ft.
TOP SPEED 189 MPH!
The Z06 is 38 pounds lighter than a standard C5 hardtop thanks to weight-saving measures such as a titanium exhaust, thinner glass, lighter wheel rims, non-EMT tires, reduced sound proofing, fixed rear radio aerial, and a lighter battery. Starting with the 2002 model year, the LS6 engine was uprated to 405 hp (302 kW) thanks to a larger volume air intake, stiffer valve springs, lighter sodium filled valves, more aggressive cam phasing and lift, revised pistons, and revised block. While Chevrolet officially claimed that the ultimate power output of the LS6 was 405 hp (302 kW), many dynamometer tests have shown that Chevrolet underrated the engine by 20 hp (15 kW), giving it an actual total of 425 hp.[1]
[edit] Performance
Factory performance figures for the 405 hp (302 kW) version of the Z06 give an acceleration time from 0-60 mph as 3.9 seconds. Owner-drivers have reportedly achieved impressive quarter-mile times of 11.7[1] seconds. This is questionable as Car and Driver recorded 1/4 mile times of 12.4 seconds for the 405 hp (302 kW) Z06 and 12.7 seconds for the 385 hp (287 kW) Z06 In their December 2002 issue. The Z06 is capable of matching or besting the 0-60 acceleration times of some of the world's premier sports cars, including the BMW Z8, Ferrari 360, and Porsche 911 Turbo (Type 996), making it one of the best performance bargains with a sticker price under $100,000 — and arguably the best performance vehicle originally sticker-priced around $50,000. Although not considered quite a supercar, primarily because production numbers are too great and top speed does not exceed 200 mph (320 km/h), the Z06 has many supercar abilities, such as a 7.33 lb/hp weight-to-power ratio as well as the performance specification marked with an asterisk in the following table:
Event Performance Supercar
Criteria
0-60 mph 3.9 sec * Under 4 sec
0-100 mph 9.2 sec
0-100-0 mph 13.56 sec[2] * Under 14 sec
1/4 Mile 11.7 sec * Under 13 sec
Skid Pad 1.03 G * Over 1 G
Top Speed 186 mph (299 km/h)
Nürburgring Nordschleife Lap Time * 7:53 * Under 8 min
Per Edmonds Car Report and Wikipedia
Last edited by Disturbed; 01-26-2008 at 02:50 PM. Reason: Forgot to add personal note
Disturbed is offline
post #3 of 16 (permalink) Old 01-26-2008, 04:41 PM
WestBoundC6's Avatar
Send a message via AIM to WestBoundC6 Send a message via Yahoo to WestBoundC6
u should walk him, year of the car dont matter my C5 was a 97 and only lost once
2005 C6
97 Procharged C5 sold but not forgotten
INFAMOUS RACING
WestBoundC6 is offline
post #4 of 16 (permalink) Old 01-26-2008, 04:41 PM
One Legged Vette Man's Avatar
Let us know the results, you should be able to take him no prob. then
GONE SUPERCHARGED
Livernois Tuned
NRA Supporting Member!
St Jude Donor!
One Legged Vette Man is offline
post #5 of 16 (permalink) Old 01-28-2008, 07:00 PM
nyvette's Avatar
Disturbed nice work on the research! No stone left unturned here!
In Memory of the fallen Heroes "We will Never Forget"
My Garage:
2005 C6
2006 Z06
2003 Land Rover Freelander
nyvette is offline
post #6 of 16 (permalink) Old 01-28-2008, 08:28 PM
Fly-n-C3's Avatar
Go and rip him up . Heck i like to mess with the new Z06 guys with my 77 making 400hp. I win a few and loose a few, but its all in fun. I may add a little spray to even things up with you guys with the 500hp Z06's. You guys are making me look bad
Fly-n-C3 is offline
post #7 of 16 (permalink) Old 01-29-2008, 01:34 AM
Disturbed's Avatar
Thanks, I try.
It's only an obsession.
post #8 of 16 (permalink) Old 01-29-2008, 04:07 AM
1985c4's Avatar
This is great i was at a drag strip in portland, Oregon and seen this same race and it was 2 friends raceing for pink slips and let me tell you the vette eat the GTO alive he beat him by atleast a car length but it was good off the line is too much for the gto and the high end torque keeps you ahead go for it you will be surprised.
1985c4 is offline
post #9 of 16 (permalink) Old 01-29-2008, 08:15 AM
cmcbunch's Avatar
Send a message via Yahoo to cmcbunch
Might be close but once you hit 100 you should take him easy. I once raced a modified cobra w/ 450 bhp in my stock 85. He thought he was hot till we got to 100. then it was over.
cmcbunch is offline
post #10 of 16 (permalink) Old 02-29-2008, 08:22 AM
Corrado's Avatar
Unless you get an EXTREMELY bad launch, you will take him pretty easily. The GTO is HEAVY, and NOT very aerodynamic.
Corrado is offline
