C4-Air Vents - SmokinVette.com Forums
post #1 of 2 (permalink) Old 01-18-2013, 12:25 PM Thread Starter
C4-Air Vents
On my 86 I am not getting air through my side vents. Everything seems to be working fine in the center vents. Any suggestions out there to check out what might be the problem?
Thanks,Jack
jalves is offline
post #2 of 2 (permalink) Old 01-18-2013, 07:08 PM
There are vac controlled actuators on the ducting that operate the vent doors.Check the vac lines running to them.
If you have elec air then the problem may be at the controller
http://www.batee.com/corvette/acrepa...oard/index.htm
that direct the vac
