How much water 1990? - SmokinVette.com Forums
post #1 of 9 (permalink) Old 12-08-2012, 06:01 AM Thread Starter
Theo's Avatar
Red face How much water 1990?
Since I burst a hose some time ago, I still get air bubbles and pockets. How much water does the whole system take then?
I quess I have never bled it properly then?
I have no water in the exhaust and oil.....
Thanks
Theo
Theo is offline
post #2 of 9 (permalink) Old 12-17-2012, 06:21 AM Thread Starter
Theo's Avatar
Talking
So by the way........
It's close to 20 litres for the whole cooling system
Theo is offline
post #3 of 9 (permalink) Old 12-17-2012, 07:02 AM
Slicktop's Avatar
Scroll down on this site for capacities for your car: http://www.corvsport.com/Corvette/C4...fications.html
1990 vette coolent is 14.6 quarts/13.817 liters
Slicktop is offline
post #4 of 9 (permalink) Old 12-25-2012, 06:36 AM Thread Starter
Theo's Avatar
I think I will have to take the intake off and check the gaskets! My car is definately using water and could suck it in through there? I have never an overpressure under the cap when cooling off or gas bubbles?
I have read on this engine some of the intake bolts go straight into the air intake system and can loose the water there. If it was head gaskets what symptoms would I have??
Thanks Guys
Theo
Theo is offline
post #5 of 9 (permalink) Old 12-26-2012, 06:23 AM
Slicktop's Avatar
Think you would have white smoke coming out the exhaust if it was real bad. If not so bad that it creats white smoke try putting a glass jar over an exhaust pipe after the engine is warmed up. If a finite amount of water is coming out it should show up as condensation on the inside of the glass. If coolent getting into the combustion chamber is indicated by either test it can be verified by other tests.
Slicktop is offline
post #6 of 9 (permalink) Old 12-28-2012, 04:00 AM Thread Starter
Theo's Avatar
Red face
Thanks for the reply!!!
Maybe I should pressure test the cooling system as well and see if it loses pressure? Since the time I burst the hose. I keep on topping up....
The other day I put in almost 1.5 litres and never started the car. Then say about 3 days later it needed water. The one exhaust is steaming when its "colder outside but goes away when the car is hot. I do not see water in the oil either. When I open the cap after cooled down, there is a suction there. I see on these engines some of the intake manifold bolts goes actually through the intake? So that menas then it can actually suck in the water say on the left bank? I first thought it was trapped air in my coolant system but now I get suspicious about it!
Theo
Theo is offline
post #7 of 9 (permalink) Old 12-28-2012, 10:16 AM
crossflag's Avatar
A presure test is the best way!
Wrap ur Azz in Fiberglass
crossflag is offline
post #8 of 9 (permalink) Old 12-28-2012, 03:56 PM
Slicktop's Avatar
Agree.........
Slicktop is offline
post #9 of 9 (permalink) Old 12-28-2012, 10:28 PM Thread Starter
Theo's Avatar
Talking
Agree.......Thanks Guys will just do that!!
Theo is offline
