oil leak - SmokinVette.com Forums
post #1 of 6 (permalink) Old 02-13-2012, 05:33 PM Thread Starter
bc.boy's Avatar
oil leak
I believe the oil temperature sending unit on my 85 is leaking.It weeps fluid onto the exhaust header and smokes. It is right close to and above the oil filter, am I right? I wouldn't want to buy the wrong sensor. any help will keepmthe brewerys happy
bc.boy is offline
post #2 of 6 (permalink) Old 02-14-2012, 05:18 AM
That's where it is!
post #3 of 6 (permalink) Old 01-29-2013, 10:57 PM
Not sure
Fuhrmanator is offline
post #4 of 6 (permalink) Old 01-30-2013, 11:21 AM
Slicktop's Avatar
The oil temperature sensor is on the LEFT (driver's) side, rear of the block, above the oil filter mounting pad.
Slicktop is offline
post #5 of 6 (permalink) Old 01-30-2013, 08:21 PM
post #6 of 6 (permalink) Old 01-30-2013, 08:24 PM
Just make sure that is the unit that is leaking and the oil is not running down the block on to it from a leaking oil pressure sensor at rear of the block under the dist
