oil coming out of dipstick? - Page 2 - SmokinVette.com Forums
post #11 of 13 (permalink) Old 09-07-2010, 07:37 PM
CorvetteDon's Avatar
Blowby pressure in crank case, check you PCV valve.
CorvetteDon is offline
post #12 of 13 (permalink) Old 09-07-2010, 08:05 PM
Originally Posted by bowlinggreendream View Post
What is up with that?
I have a 1990 and it's not a ton of oil but enough to get me concerned.
All you can do is check your PCV valve. If it's okay, then you may have a piston ring problem. How does your engine run otherwise? If it runs good and doesn't use much oil, I wouldn't worry about it.
post #13 of 13 (permalink) Old 09-08-2010, 12:22 PM
1996 LT-4's Avatar
That seems like it would be a ton of crank pressure.
1996 LT-4 is offline
