smog pump - SmokinVette.com Forums
post #1 of 28 (permalink) Old 07-10-2010, 08:09 PM Thread Starter
smog pump
how do i remove the smog pump on my 86 vette
edelfyette is offline
post #2 of 28 (permalink) Old 07-10-2010, 08:13 PM
InjectorsPlus's Avatar
Do you plan on removing it or replacing it?
Office:201-258-5600
Cell:201-403-3699
www.injectorsplus.com
www.facebook.com/InjectorsPlus
Custom fuel injectors for any application, marine, ATV, etc
Tuning stock and aftermarket ECUs
Fuel Pumps----Areomotive and Fuel Labs
Lines Fittings ---- Red Horse, Fragola, XRP
MARCELLA CUSTOM INTAKES
ECU-----Fast, Holley, and Motorvation
Intakes Manifolds for LSX, SBC, SBF, BBC
Carb to FI conversion kits
If it's fuel related and you don't see it, CALL, we can make it.
InjectorsPlus is offline
post #3 of 28 (permalink) Old 07-10-2010, 08:20 PM Thread Starter
I want to take it off
post #4 of 28 (permalink) Old 07-10-2010, 08:26 PM
Unbolt the bracket, you'll need the eliminator bracket probably from Ecklers or Mid America.
Take out the tubes on top of the headers. I say cut them off and weld up the holes.
Also, there's a black box that sits under the throttle body. There's a bunch of wires that go to it to activate solinoids. Get rid of all that.
there's a bunch of hoses too that run in and around the t-stat housing and such.
get rid of all that crap. 30 lbs of useless stuff.
It's an easy job, you'll be AMAZED how much crap comes out and how much more room you'll have without it in there.
There's a hard stainless line that goes down to the converter. That will be the hardest thing to deal with.
Office:201-258-5600
Cell:201-403-3699
post #5 of 28 (permalink) Old 07-10-2010, 08:32 PM Thread Starter
thanks ill give it a try in the morning
post #6 of 28 (permalink) Old 07-10-2010, 08:34 PM
Do you have the eliminator bracket and pulley?
Office:201-258-5600
Cell:201-403-3699
post #7 of 28 (permalink) Old 07-10-2010, 09:41 PM
robs1988's Avatar
You don't really need to spend the money on the eliminator bracket. You can gut the smog pump by breaking off the plastic fins inside of it. Reinstall smog pump, and it will work fine as a pulley, provided it spun fine before. I did, works with no probs.
Go to the hardware store and get some nice brass caps to cap off the exhaust manifold tube.
robs1988 is offline
post #8 of 28 (permalink) Old 07-10-2010, 09:54 PM
Originally Posted by InjectorsPlus View Post
There's a bunch of wires that go to it to activate solinoids. Get rid of all that. .
Make sure you tape up the redundant wires safely.The pink / blacks are hot with the key on
post #9 of 28 (permalink) Old 07-11-2010, 05:18 AM
mat helm's Avatar
Do what he said. I'm tellin' you guys I went through this in the 90's. Don't tear off all the smog crab because the enviro-police will be coming back, and then you'll be hunting all this imposable to find stuff. By pass all the emissions crap but make it appear as though it's still there.
mat helm is offline
post #10 of 28 (permalink) Old 07-11-2010, 05:39 AM
Then what's the point? To me the point was to clean stuff up so that I could work under there.
After the first five minutes, it has Zero effect on emissions.
Office:201-258-5600
Cell:201-403-3699
