1988 no injector pulse - SmokinVette.com Forums
post #1 of 21 (permalink) Old 11-29-2009, 11:51 AM Thread Starter
I changed the intake manifold gasket and now have no injector pulse.I have checked everything and can not find the problem.
Used noid lamp and no pulse
Have VATS bypass, tried with and without
Tried spare key,checked reading of keys
and VATS bypass
Oil pressure switch works,and tried a jumper
Fuel pump runs and pressure at rails
Have power at both injector harness wires
Changed distributor
Changed ECM
Need help,Thanks
dave5950 is offline
post #2 of 21 (permalink) Old 11-29-2009, 01:49 PM
Bob Perry's Avatar
Same Problem
and VATS bypass
Changed distributor
Changed ECM
Need help,Thanks
I have the similiar problem, although am not sure about "injector Pulse" How did you check this? I unplugged an injector wire at the plug, with the key on I have battery power (12v )at the plug. The injectors have to trigger with the rotation of the engine, so are the injectors adding gas when they are powered with electricity or with no power? I don't know what a "noid lamp" is if that is what is needed to check pulse. I will monitor your post in hopes that your fix is also my fix.
Bob Perry is offline
post #3 of 21 (permalink) Old 11-29-2009, 02:31 PM
95vette's Avatar
You can buy or even borrow a noid light set from Autozone. The set costs $25 or they rent them for free. Unplug the wire from the injector and plug the light in instead. When you try to start the light should pulse rapidly indicating the ECM is supplying the ground to the injector. Since the positive power is constant it is the ground that activates the injector, which in turn injects gas into the intake. A proper test is to do all 8 injectors one at a time. Hope this helps you.
95vette is offline
post #4 of 21 (permalink) Old 11-29-2009, 02:47 PM
CFI-EFI's Avatar
Changed distributor
Need help,Thanks
The ECM only pulses the injectors when it receives the pulses from the distributor, that are generated once the engine begins to turn, much as it re energizes the fuel pump relay when the engine is cranking.
If the engine cranks, it is not a VATs problem.
The oil pressure switch has zero, zip, nada , to do with the pulsing of the injectors.
Depending on when you observed the fuel pump running it may or may not indicate the distributor is sending pulses.
Was the distributor replaced as an adjunct to the gasket job, or was it done in hopes of getting it running again?
RACE ON!!!
CFI-EFI is offline
post #5 of 21 (permalink) Old 11-29-2009, 03:50 PM Thread Starter
The distributor in the car was new,the one I put now was my old one that worked when I took out a month ago.I did this a check to see if this was the problem.
dave5950 is offline
post #6 of 21 (permalink) Old 11-29-2009, 03:58 PM Thread Starter
I did use the noid lamps and they did not light with key on or cranking over.There is power to both injector harness wires with key on.
dave5950 is offline
post #7 of 21 (permalink) Old 11-29-2009, 04:11 PM Thread Starter
I did use the noid lamps and they did not light with key on or cranking over. There is power to both wires on the injector harness with key on
dave5950 is offline
post #8 of 21 (permalink) Old 11-29-2009, 04:17 PM Thread Starter
RACE ON!!!
The distributor in car was new and the one I have in now was the the one I took out a month ago that was working.I did this for a test to see if it was the problem
dave5950 is offline
post #9 of 21 (permalink) Old 11-29-2009, 04:26 PM
Bob Perry's Avatar
Same Problem Different Car
I have power to both wires on mine too with the key on.
If the injectors inject fuel when the power is off and shut off when the power is on, can I unplug four of the injectors and get the thing to run?
post #10 of 21 (permalink) Old 11-29-2009, 04:37 PM
No
Like many other items in your car, the injectors have 12V supplied to them when the key is on.
The injectors spray fuel by the computer putting the other wire to ground completing the circuit (power ON )
