*NEW* Coupe/ZR1/Z06/Grandsport Wind Restrictor Glow Plate - SmokinVette.com Forums
post #1 of 1 (permalink) Old 11-30-2012, 12:43 PM Thread Starter
:thumbs:No longer just a Convertible thing:thumbs:
This is ONLY available through"TheDoubleAA.com". We have spent about a year to make sure everything was absolutely perfect from fitment all the way to ease of install.
For the next 10 days we can guarantee free shipment to you in time for Christmas and offering "FREE" customizing.
- How hard is it to install?
This has a similar design to the partitions available and just slides right into place. For the lighting you remove the panel on the back (4 grommets) and tie in power from tail lights and done... Should be a less than 15 minute job.
- Will my top fit in with this installed?
Yes, it was specifically designed so that the tops could be stored with the Glow Plate in place
- I have a Vette bin, will this work together?
Yes. The fitment is perfect and slides right into place.
- What models of vehicles will this fit?
This will fit all coupe style models including ZR1, Z06, Grand Sport Coupes and Coupes.
- What all options are available?
Everything that is currently offered for the convertible wind restrictor will be available for the Coupe Glow Plate Wind Restrictor including:
Accessories for Wind Restrictor
Brake Lamp Module with Dimmer knobs - (Works with the brake lights to increase intensity and decrease when you touch the brakes, also comes with a 9v battery system to run when the car is off or battery disconnected)
Dimmer Control Module (remote control brightness, dimmer and on/off controller)
12V Power Plug (cigarette lighter plug)
on/off switch
Battery Pack
Andrew6 is offline
