Antenna wont go down - SmokinVette.com Forums
post #1 of 6 (permalink) Old 08-26-2012, 06:02 AM Thread Starter
bigdogjack's Avatar
Antenna wont go down (motor is running), how does that work and is it hard to get to?
bigdogjack is offline
post #2 of 6 (permalink) Old 09-11-2012, 11:44 AM
Raydawg357's Avatar
Did you install a new stereo? If so, you may connected the wrong blue wire to the antenna wire. If not, the power antenna works off of 3 wires: constant, ground and switched power. If you still have the OEM setup, the antenna could be going bad. Aftermarket replacements average around $60.
"I'm addicted to naked pictures and talking about B!#*^$ that I almost had"..........Drake
Raydawg357 is offline
post #3 of 6 (permalink) Old 09-12-2012, 11:54 PM
Snowweasel's Avatar
Smile
Try a little grafite spray ,on the shaft.put on the sray and help push it down when the motor is going down
Snowweasel is offline
post #4 of 6 (permalink) Old 01-22-2013, 08:29 AM
alfredo65's Avatar
There's a toothed wire that joins to the mast and is rolled away by the engine to take the aerial mast down. It's typical for older ones to break.
alfredo65 is offline
post #5 of 6 (permalink) Old 01-22-2013, 02:10 PM
MarkyMark's Avatar
I don't know if this will help. I see that you have a C5. But look at my posting "Removing and replacing antenna mast." (C4 Tech) Also look at photos in my gallery. Detailed photos. My posting & photos may give you some idea. Any questions, feel free to contact me.
MarkyMark is offline
post #6 of 6 (permalink) Old 02-27-2013, 01:08 PM
Seems silly to ask but... have you checked the ground wire on it?
6781camaro is offline
