1990 original radio - SmokinVette.com Forums
post #1 of 3 (permalink) Old 06-01-2010, 09:10 AM Thread Starter
Theo's Avatar
1990 original radio
I am installing the original radio/cd/casette player and tooki the up-market one out. So far no problem but cannot see where the antenna plugs in? There is no plug at the back unless its that square hole? The antenna plug now is with a pin. Can I just connect it to the housing of the radio?
Theo is offline
post #2 of 3 (permalink) Old 06-02-2010, 06:09 AM
mat helm's Avatar
Just took mine out too and from what I've read on crutchfield, and seen on mine, there isn't one on the bose systems. To add a after market radio you have to use a converter plug. Not sure what to do if you're trying to use a bose radio to a non bose vette.
mat helm is offline
post #3 of 3 (permalink) Old 06-02-2010, 11:58 AM
Raydawg357's Avatar
Some of the older amplified set ups (depending on the model), the antennea plugged into the amp and not the radio. This was the case on most older versions of BOSE.
"I'm addicted to naked pictures and talking about B!#*^$ that I almost had"..........Drake
Raydawg357 is offline
