Holley Street avenger 670 CFM - SmokinVette.com Forums
post #1 of 5 (permalink) Old 08-11-2010, 10:33 AM Thread Starter
I have Mixture screw set 3/4 turn but still running rich? what else can i do?
fordean is offline
post #2 of 5 (permalink) Old 08-12-2010, 10:12 AM
Is your choke disengaging properly? You could have a bad powervalve thats leaking fuel,or a powervalve thats too high for your manifold vacuum,opening at idle..your float levels may be too high, or not closing off needle and seat. too high fuel pressure..should be no more than 6psi at 2000rpm...what s in the motor
post #3 of 5 (permalink) Old 08-14-2010, 11:46 AM Thread Starter
I have about 6.5. Psi, I have a feedthru Carb. Barry grant I dont know which powervalve I have. I will look and get back to this post. Floats. we did. But it is a pain to do. Dont know why they just dont have a sight hole that you need to play around with. Small glass sight I dont think would be real dangerous but maybe it is.
fordean is offline
post #4 of 5 (permalink) Old 08-15-2010, 12:37 PM
if you have a fuel pressure regulator, lower the pressure to 6.0 or even 5.5psi...too much pressure overcomes the floats ability to close the needle.
post #5 of 5 (permalink) Old 08-15-2010, 05:48 PM Thread Starter
ok I will step it down to 5.5 psi. Thanks.
fordean is offline
