Auto Trans questions - SmokinVette.com Forums
post #1 of 4 (permalink) Old 12-04-2012, 04:43 PM Thread Starter
My trans temps run around 170-195 on a hot day. I keep up on the service. I know a external cooler would help but should I be worried. My vette will not see any tract track time. i just drive the hell out of it 50% of the time
VVCH EMT is offline
post #2 of 4 (permalink) Old 12-04-2012, 07:50 PM
Gigity's Avatar
That's right where you want it. Less than 150 F is generally considered too cold, 275 F is generally considered the max for short durations. Automatic transmission oil can provide up to 100,000 miles of service before oxidation requires replacement, at an operating temperature of 175 F. Above this temperature, the oil oxidation rate doubles with each 20 degrees F increase in fluid temperature. At 195 F, you should plan on changing the fluid at 50,000 miles, etc.
Forged 402 Stroker, 856 RWHP/750 RWTQ, Paxton Super Charger @ 20 PSI, ECS Big Blower Cam, American Racing Headers, 3.73 rear, Corsa Extreme Exhaust, Methanol Injection, Pfadt Coil Over Suspension, ECS Fully Built M6 Transmission Swap
Gigity is offline
post #3 of 4 (permalink) Old 12-05-2012, 03:32 AM
Gig s right..yours is normal ..temps will go up in heavy traffic, slow moving, but short periods are OK .. When you change the fluid, Synthetics are far superior to convenional and usually run 10-20 degrees cooler ...and welcome to SV
post #4 of 4 (permalink) Old 12-05-2012, 05:37 AM
I would check to see if any trash has been sucked up in the radiator,these bottom feeders suck up plastic bags sometimes that cut cooling .not that yours is heating up.
