Clutch pedal goes to the floor and sticks - SmokinVette.com Forums
post #1 of 15 (permalink) Old 12-07-2008, 02:59 PM Thread Starter
intercepter47's Avatar
One of the dealers said it could be a master cylinder leaking but I don't see any fluid on my engine or on my garage floor.
It sometimes sticks when I shift gears and it doesn't matter what gear is involved.
Any ideas what is going on with the clutch ?
Thank you,
Greg.
intercepter47 is offline
post #2 of 15 (permalink) Old 12-07-2008, 03:49 PM
BLU COLLAR Z's Avatar
Have you looked at your clutch fluid lately? i bet its black as coal , you need to suck this old nasty fluid out and replace with dot 4, pump the pedal 25 times check color of clutch fluid and repeat until its clear i think this will fix your problem. I change my clutch fluid every time i drive the car
BLU COLLAR Z is offline
post #3 of 15 (permalink) Old 12-07-2008, 07:03 PM Thread Starter
Clutch master cylinder ? I heard of a master cylinder for brakes but not for a clutch.
When the clutch sticks to the floor, I have to "pop" it back up with my toe, slipping my toe underneath it.
Still sounds like the fluid needs to be drained and replaced ?
Thanks again,
Greg.
post #4 of 15 (permalink) Old 12-07-2008, 08:13 PM
Thanks again,
Greg.
YES,YES,YES Answer lies above
post #5 of 15 (permalink) Old 12-07-2008, 11:20 PM
Junkman2008's Avatar
I don't even have a MN6 and I've read about this problem a ton of times. Sometimes you have to change the fluid, drive the car and change it again. I bet yours is in that shape.
"Marines - Making the other guy die for his country for over 200 years."
Junkman2008 is offline
post #6 of 15 (permalink) Old 12-08-2008, 12:24 AM
tstar's Avatar
Change your fluid, that usually fixes the problem. If you're still having problems a clutch stop or a change in driving style that limits how far you push the clutch down is in your future...
Tim
99 MN6 Coupe
New XS Power Headers STD 345.4/355.7
STD 344.4/347 SAE 337.5/340.2
Performance = Hurricane CAI w/Volant Airbridge/coupler, LTs, Highflows, X Pipe thru Corsa Indy's, RSD Snap, Tuned
Suspension/Brakes = 3/8" Tunnel Plate, Hotchkis Sways/ 355mm BBKs
Cosmetics = Vent screens, Clear/Chrome lights, Red bumper letters, Chrome 2010 C6 wheels, Custom Leather
DIY Mods = Radiator Screen, Painted Calipers/Hat and Hood Liner, Red Interior Lights, Gill Lights, Frost King
tstar is offline
post #7 of 15 (permalink) Old 12-11-2008, 12:34 PM
This is a service VME regarding 1997 through 2002 Corvettes. We’ve had several complaints of the clutch pedal not returning when depressed. If air gets into the hydraulic clutch system, the clutch pedal may not return when depressed. This may occur at low speeds, when stopped or possibly during high RPM shifts. One source of this condition may be the clutch slave cylinder. If the clutch pressure plate was not evenly torqued to the flywheel it may have been distorted. This could result in the clutch release fingers being uneven causing the clutch slave cylinder to wobble. This wobble will eventually damage the internal seal and the slave cylinder allowing air to enter the system. If this situation is present the recommended repair is to replace both the clutch slave and clutch master cylinders. A visual inspection of the pressure plate release fingers for wobble, which would appear similar to a bent wheel, should be performed when servicing the slave cylinder. If the release fingers are found to have this condition, it will also be necessary to replace the clutch assembly. Evenly torquing the pressure plate to the flywheel is necessary to prevent this condition.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance. This diagnostic approach was developed for the vehicle with the VIN you entered and should not be automatically be used for other vehicles with similar symptoms.
LOUIEINLI is offline
post #8 of 15 (permalink) Old 12-11-2008, 12:39 PM
I still bet it's dirty fluid.
post #9 of 15 (permalink) Old 12-11-2008, 12:53 PM
No doubt
post #10 of 15 (permalink) Old 12-11-2008, 07:04 PM
Smokin 2000HP Road Racer
hammatime's Avatar
Last time that happend to me it was the slavecylider.
hammatime is offline
