Changing clutch fluid - SmokinVette.com Forums
post #1 of 4 (permalink) Old 11-21-2008, 07:24 AM Thread Starter
airwolf99's Avatar
Should I get the DOT 5? I am assuming that seeing it is higher then 4 it should be better?
airwolf99 is offline
post #2 of 4 (permalink) Old 11-21-2008, 08:53 AM
BLU COLLAR Z's Avatar
The problem with Dot-5 silicone fluid is that it absorbs air causing air bubbles in the fluid, giving a mushy pedal. Use Dot-4; it is better than Dot-3 (higher boiling point with Dot-4), easy to obtain, & inexpensive.
BLU COLLAR Z is offline
post #3 of 4 (permalink) Old 11-29-2008, 09:16 AM
Ron222's Avatar
Should never mix Dot 3 or Dot 4 with dot 5. It's a no no.
Ron222 is offline
post #4 of 4 (permalink) Old 11-30-2008, 07:47 AM
nuclearpowered's Avatar
You know, I just assumed that they were the same stuff just progressively better.
nuclearpowered is offline
