Better Fuel Mileage At Higher Speeds Than At Lower Speeds - SmokinVette.com Forums
post #1 of 11 (permalink) Old 02-05-2013, 10:10 AM Thread Starter
After installing my TH700R4 I found my '71 would only get 12 mpg at 55 mph but 16 mpg at 70-75 mph which didn't make a bit of sense. I knew my engine loped clear up to 1300 rpm because of it's marine cam but I never thought much about it until I realized I was running around 1300 rpm at 55 mph. Hmm.
So I installed a set of 3.70's and that brought my 55 mph cruising rpm up about 300 rpm and that did the trick as I now get 14-1/2 mpg at 55 mph and the same 16 mpg at 70-75 mph. So it was just a matter of my components being mismatched. And with the 17% lower gears my car is much more responsive in all gears and at all road speeds.
post #2 of 11 (permalink) Old 02-05-2013, 10:30 AM
bluedawg357's Avatar
Steve do you think that this is due to the operating range of the camshaft?
bluedawg357 is offline
post #3 of 11 (permalink) Old 02-05-2013, 04:01 PM Thread Starter
I am thinking it was because at 55 mph my engine was still loping because of the longer duration marine camshaft. I live in an area in which the traffic moves along at 55 mph or less and the roads are all two lane roads with lots of oncoming traffic. So it's very hard to pass anyone for sometimes 20-25 miles. But when I could get the revs higher the fuel mileage instantly improved which made me suspect the low rpm and camshaft were causing the low fuel mileage.
The moment I put the 3.70's in my fuel mileage improved a whopping 22% at my usual 55 mph cruising speed so it appears I was right for suspecting the low rpm and camshaft combination. And with the lower gears my engine is much more responsive in all gears and road speeds. I have to pull a 10 mile long 6% grade coming home and with the lower gears it pulls the grade much easier in 4th gear because it's running 300 rpm faster.
post #4 of 11 (permalink) Old 02-05-2013, 08:29 PM
What are the cam specs?
post #5 of 11 (permalink) Old 02-06-2013, 10:21 AM Thread Starter
The marine cam's specs are 220 degrees intake, 220 degrees exhaust, and .500" lift. Nothing real wild but still a lot more than stock. I'm running it 4 degrees advanced to improve it's low end performance.
post #6 of 11 (permalink) Old 02-11-2013, 11:03 AM Thread Starter
Real Good Combination
I have found a set of 3.70's behind a TH700R4 is a terrific combination as my '71 will easily run 120 mph in 4th but get much better performance in the lower gears. And, I also got a 22% increase in my fuel mileage because my engine is operating at a better rpm at cruising speeds.
post #7 of 11 (permalink) Old 02-11-2013, 12:35 PM
thats what we are always talking about...matching components for optimum results
post #8 of 11 (permalink) Old 02-11-2013, 09:08 PM
Probably enough cam to be lugging at 1300 rpm, 220 duration @ .050" lift probably as an rpm range sttarting at 1500 rpm, not that youd notice with the off idle torque of your 454, but enough difference at 1300 rpm to change economy.
post #9 of 11 (permalink) Old 02-12-2013, 03:15 AM
its not just the cam, its also the large runners on the RPM Air Gap, not efficient at low rpm
post #10 of 11 (permalink) Old 02-12-2013, 09:59 AM
Exclamation
I believe it is due to the dist. adv. curve. At 1300 RPMs you are barely into the mechanical advance, although you should have vacuum advance.
