One Bad Brake - SmokinVette.com Forums
post #1 of 18 (permalink) Old 01-05-2013, 09:23 AM Thread Starter
david78's Avatar
Question One Bad Brake
I am currently braking with 3 wheels ( the 2 front & passenger rear) I bled the system but the caliper was stiff so I bought a new one but I am still having the same problem
I get oil but it does not seam to have pressure to stop the disk
Any Advise.... Comments
Thanks_DAV 78
david78 is offline
post #2 of 18 (permalink) Old 01-05-2013, 11:27 AM
lostvette's Avatar
Brake !
Did U Change UR Brake Hose ?
lostvette is offline
post #3 of 18 (permalink) Old 01-05-2013, 06:42 PM Thread Starter
david78's Avatar
The lines are steel tubing and seem to be clear
the only possibility I can think of is a partially clogged line so disconnecting everything and blowing compressed air into it
david78 is offline
post #4 of 18 (permalink) Old 01-06-2013, 11:42 AM
sometimes the rubber hoses degrade and cause issues , although this is rare.
post #5 of 18 (permalink) Old 01-07-2013, 04:14 PM
David, if your lines are clear,and you are sure you have all the air out of the system, and it still has no pressure to the rear , I would suspect the Master Cylinder
post #6 of 18 (permalink) Old 01-08-2013, 04:04 AM
but that would be an issue for 2 wheels if you have a double resevoir
all four if it's a single......perhaps a proportioning valve blockage ?
post #7 of 18 (permalink) Old 01-08-2013, 06:08 AM
it very well could be.. I was thinking that its farthest from a weak M/C , less pressure
post #8 of 18 (permalink) Old 01-08-2013, 09:18 PM Thread Starter
david78's Avatar
I haven't had the time to look into it but I have a day off tomorrow
the master cylinder was replaced and it is under warranty so might change that as well but isn't the driver side the closest?
david78 is offline
post #9 of 18 (permalink) Old 01-09-2013, 04:32 AM
I thought it was Right Rear... are you absolutely sure the line is clear and all air is purged ? it is possible that its still in the caliper, is that a rebuilt? or like EX said, maybe proportioning valve
post #10 of 18 (permalink) Old 01-09-2013, 07:05 AM Thread Starter
david78's Avatar
To Say the truth, I over bled
it is rebuilt
david78 is offline
