370 gears - SmokinVette.com Forums
post #1 of 7 (permalink) Old 12-25-2012, 01:43 PM Thread Starter
kenny k's Avatar
370 gears
I replaced my 302 rear and put in 373 gears . I was reading a post that talked about changing a plastic gear in the speedo, to get an accurate reading on mph. Is this a diffulcult proceger ?
kenny k is offline
post #2 of 7 (permalink) Old 12-25-2012, 05:24 PM
david78's Avatar
WHAT TRANSMISSION?
year?
david78 is offline
post #3 of 7 (permalink) Old 12-25-2012, 06:09 PM
you will need to match the drive gear and driven gear tooth counts to get an accurate speedometer reading. according to Rear Axle ratio and tire diameter ... the driven gear is easy, its inside where the cable attaches.. the drive gear requires removing the tail housing .neither are that difficult.. available from all the vendors....Dave, like the " Control " slogan
post #4 of 7 (permalink) Old 12-25-2012, 09:03 PM
david78's Avatar
Thanks ( its a shame guns have a bad reputation when all they do is make me happy
especially my AR-15 :-D
Here are the steps to remove the drive gear and the driven gear
http://www.73-87.com/7387garage/drivetrain/spdgears.htm
david78 is offline
post #5 of 7 (permalink) Old 12-26-2012, 08:20 AM Thread Starter
kenny k's Avatar
1971 corvette ,I picked up a 373 rear and replaced the 302 rear ,it has a munci 4 speed m21 or m20 can't recall but its the one with the lower first gear.Thanx k.k.
kenny k is offline
post #6 of 7 (permalink) Old 12-26-2012, 01:18 PM
Kenny, to correct your speedometer you'll need the correct nylon drive and driven gears that go into your transmission. PATC and TCI sells them and they're not expensive; usually around $11-$15 each. As the drive gear mounts on the transmission's output shaft you'll have to pull your tailhousing to replace it. E-mail me at sw82vette@yahoo.com and I'll give you all the information you'll need.................
post #7 of 7 (permalink) Old 12-26-2012, 04:35 PM Thread Starter
kenny k's Avatar
Thanks.k.k.
kenny k is offline
