Fuse panel - SmokinVette.com Forums
post #1 of 3 (permalink) Old 12-14-2012, 03:01 AM Thread Starter
kenny k's Avatar
Fuse panel
I need a place to attach a power wire from my radio. Im using one prong for the elictrice choke another for my distributor another for a second wire from some kind of inline fuse going to the radio.can you power two wires from one prong?thanks k.k.
kenny k is offline
post #2 of 3 (permalink) Old 12-14-2012, 03:15 AM
I see you have a '71 like I do so let me warn you of something. The BAT terminal is unfused and the IGN terminal is heated by the ignition switch. Over time the contacts in ignition switches get worn to the point of no longer making contact so I highly recommend you replace your ignition switch based on years-of-use alone. New ignition switches are about $15 and are fairly easy to replace; maybe an hour's worth of work.
You can power a dozen things from one terminal as long as the combined load doesn't exceed the terminal's rating. In your case the things you are powering are small so feel free to connect several to one terminal.
post #3 of 3 (permalink) Old 12-24-2012, 12:04 PM Thread Starter
kenny k's Avatar
Thanks for the advice. Also happy holidays to all.
kenny k is offline
