Strut Rod Warning - SmokinVette.com Forums
post #1 of 7 (permalink) Old 12-13-2012, 02:12 PM Thread Starter
Strut Rod Warning
My left-side strut rod broke a couple of days ago and I damned near lost control of my '71. As I was on a twisty-turny mountain road at the time I had to continue driving an additional 7 miles until I could find a straight section to turn around.
Upon inspection I found these strut rods were apparently Chinese-made as the threads were metric, die cut, and the end studs had been welded onto the bushing eyes. Certainly very poor quality and very unsafe as well.
So if you decided to buy adjustable strut rods be very careful to only buy top quality American-made stainless steel strut rods. It could be a matter of life or death.
By the time I got back home my tire was almost on fire from the friction of rubbing against the inner fender.
post #2 of 7 (permalink) Old 12-13-2012, 02:59 PM
thats dangerous... they appear to be poor quality..
post #3 of 7 (permalink) Old 12-13-2012, 10:19 PM
bkemp's Avatar
Never saw stainless strut rods, what vendor handles them.
bkemp is offline
post #4 of 7 (permalink) Old 12-14-2012, 02:42 AM
I have the Stainless Steel Adjustable Strut Rods on mine...I got them about 5 years ago ..Ecklers ,I think
post #5 of 7 (permalink) Old 12-14-2012, 03:11 AM Thread Starter
I should have noted the picture shows the broken strut rod and the forged stainless steel replacement side-by-side.
post #6 of 7 (permalink) Old 12-15-2012, 02:06 AM
I did a search, it looks like the Stainless rods are very hard to find now.. but, Forged Steel rods are available ..you just don t want that cheap Chinese made crap with poorly welded ends or you ll experience what Toobroke did
post #7 of 7 (permalink) Old 12-15-2012, 08:21 AM Thread Starter
I found the bushings they use have an outer steel shell that is 1/8" thick and an inner steel sleeve. What they did was simply weld the threaded end directly to the outer shell. From close inspection I can see where the weld began to fracture then work it's way across to the other side and then let go. And down my car went.....................
